battery-module-internal-resistance-meter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pnitin, Sep 5, 2025.
  1. pnitin
    pnitin Junior Member
    I’ve been working on repairing the aging NiMH battery modules in my 2004 and 2012 Prius. Some cells had started failing, so I began the replacement process, slowly swapping out modules one by one.
    However, I quickly realized this approach was inefficient. Simply checking module voltage isn’t the most reliable way to determine battery health. While you can easily find used Prius battery modules on eBay or through local sellers, most only list the battery voltage—often measured right after charging—as proof of a “good” module. Unfortunately, this isn’t always accurate, and many times you discover the module doesn’t actually perform as expected once installed.
    A much better method is to measure both the module’s voltage and its internal resistance. Internal resistance is a strong indicator of battery health—low resistance cells are more efficient, less lossy, and deliver more consistent performance.
    As an electronics enthusiast, I built a simple meter that measures internal resistance. It runs on a basic 9V battery, is cost-effective, and makes it much easier to evaluate the true condition of hybrid battery modules. We’ve even launched a Kick-starter to make this tool accessible to anyone who wants to test, repair, or optimize their own hybrid battery packs.
    https://www.kickstarter.com/projects/1842571016/hybrid-battery-module-internal-resistance-meter
    sending this in hope this is helps someone like me to get battery in shape back.
    Thanks
    Nitin
    PriusCamper likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,675
    2,478
    Durham NC
    Most people are trying to clear out the junk modules that they have in boxes laying around they're not going thru all that . That's end user job .
  3. pnitin
    yes very true. On the other side as buyer has to be more educated in choosing what is right for him/her, and that is where I think it will help.
  4. Tombukt2
    13,675
    2,478
    Durham NC
    Yeah. You'll have to be able to walk up to the box of modules and have at it . seems really quick to me 28 new modules would be best. As in New battery.
    frodoz737 likes this.
  5. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    Can you sell me one today, not in december?
  6. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Does the kickstart includes a rubber mallet?
