Battery not charging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by galileofigaro, May 12, 2021.
  1. galileofigaro
    galileofigaro Junior Member
    37
    2015 Prius Plug-in
    2015 PIP with 62K miles.
    Battery charges up to a certain point as show. Will only charge when going down the hill or by plugging it to power. This issue started to happen in the last 2 months.
    No warning lights yet.
    Should I worry about replacing the battery? I though I was supposed to at around 160k miles.
    Warranty covers within the 100k miles but I'm not the original owner. Am I still covered?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That looks totally normal for a plug-in that hasn't been plugged in for a long time. Charging will be limited to HV capacity when only engine power is available.
    jerrymildred likes this.
    52,854
    what was it like before 2 months ago?
    are you sure the warranty isn't 10/150?
    yes, the warranty is transferable
  4. Tideland Prius
    16,680
    You say 62,000 miles but the odo in the picture says 81,600 miles. So, how many miles are on your car?
    Hybrid battery warranty is 8 years or 100,000 miles (except in CA emissions states). Depending on the “in service date”, you may be out of warranty due to time.
    bisco and jerrymildred like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Looks normal to me. That's the way PiPs and Primes work.
