Battery not fully charging
Discussion in 'Gen 4 Prius Main Forum' started by Coachsteve, Mar 22, 2019.
  1. Coachsteve
    Coachsteve New Member
    North Carolina
    2019 Prius Prime
    I have a one week old 2019 Prius..loving it. However, the battery indicators never show more than about half full. Is this ok? Is the indicator not accurate typically? Does it require more highway driving than I’ve had to fully charge it? Thanks...
  2. Tideland Prius
    16,683
    The regular Prius or Prius Prime (as you indicated in your profile)?
    If the regular Prius, it should sit around the 60%-80% mark on the battery display. It'll never be full since you want that buffer for brake regeneration (e.g. you go down a steep hill)
    FuelMiser likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    After you've plugged in and charged your PRIME - what battery level does it show? My understanding is that the whole PRIME battery won't fully recharge in normal driving, but only with plugging in and charging.
    It would have been better to post this on the PRIME Forum - you'll get PRIME owners answering.
    If you hit the upload_2019-3-23_9-22-14.png button, you can request this thread be moved to the PRIME Forum.
    52,891
    perfect
