Battery not working after fix. My 2005 Prius is still having battery issues
Discussion in 'Newbie Forum' started by Lisa van de Velde, Dec 16, 2018.
  1. Lisa van de Velde
    Lisa van de Velde New Member
    Sacramento, CA
    My 2005 battery is still having problems after we replaced the battery cells that were low. We changed the cell and replaced the 12 volt. It was fine until I ran into a pothole and the battery immediately dropped and the indicator board lit up. Two days later the lights were gone and it worked fine. This was about two weeks ago. Last night it started acting up again. The battery dropped from high to low quickly, and back up again. The indicator lights haven't come on yet, but I know that is how this generally goes. The car has 190,000 miles on it. Is it time to let Prius retire? I hope not because I am still making payments
    Please advise.
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    49,510
    was everything properly torqued down after repairs? potholes seem like the smoking gun
    are you related to peter van de velde? he was a fabulous merc mechanic
    Skibob likes this.
  4. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    Battery reconditioning is an essential process of rebuilding a battery pack... Replacing a bad cell when it's obvious via voltage readings is a good first step, but a more thorough job to identify other bad cells before they go bad is essential. Though if your problem is related to hitting a pothole that would mean there's a loose connection somewhere. Let us know how we can help by including more details about the work you did as well as the work you'd be willing to do more of?
    Skibob likes this.
  5. Skibob
    2,912
    1,496
    Northern California
    Listen to this man. He has done this before with success.
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If it really immediately died after hitting a giant pothole, that says something isn't connected properly or fully to me. And a loose HV battery connection can be dangerous as there is a lot of current flowing through those bars. A loose connection is a hot connection.
    Skibob and PriusCamper like this.
