Battery Pack info from Car Scanner and Torque Pro
Discussion in 'Gen 3 Prius Technical Discussion' started by Wobblybike, Jan 8, 2024.
  1. Wobblybike
    Wobblybike Junior Member
    23
    Los angeles
    Hello ... Hope someone can help to identify if my battery pack is doing fine or not.... base on a review on Utube, it says if all the charging are near one another they are good or if theyre not than the pack is near the end . Please help me figure this out as my daughter is going to college with the car... Thanks in advance. I'm posting the pictures. sorry I can't seem to post the pictures. I"ve been at it for 30 mn....so here are the numbers while driving.
    Aux battery voltage 14.51
    Battery block 1: 16.61
    Battery block 2 16.59
    Battery block 3: 16.63
    Battery block 4: 16.61
    Battery block 5: 16.61
    Battery block 6: 16.59
    Battery block 7: 16.59
    Battery block 8: 16.63
    Battery block 9: 16.54
    Battery block 10: 16.54
    Battery block 11: 16.59
    Battery block 12: 16.56
    Battery block 13: 16.54
    Battery block 14: 16.56
    Soc Min 52.5 / Soc Max 75.5
  2. ASRDogman
    ASRDogman Senior Member
    8,023
    4,072
    Mine was close like that.
    You should get the Prolong charge/discharge system and run it.
    It has helped my battery. Well worth the money!
  3. Wobblybike
    23
    Los angeles
    Sorry but when you Mine was close to that... Meaning was or is..... I'll the check the prolong. thanks
  4. ASRDogman
    8,023
    4,072
    The voltages. Mine were within .06 of each other.
    I ran the 3 discharge and 4 charge cycles with the prolong system and it
    made a difference on how it the Prius charged and discharged it.
    It was just over a year when I noticed it was sitting at the 2 bar longer on the
    charging. So I ran it again. It's lasting about 8 months so far.
    It's going to be at least a year and a half before the prices start to drop for a new
    complete battery. And I just want to keep it alive until then.
    90% of my driving in highway so I think it will last...
  5. Wobblybike
    23
    Los angeles
    Thank you for the reply..... so would you say I"m good for now.....?.... thanks again.... also where do I get the prolong system?
  6. ASRDogman
    8,023
    4,072
