Battery Pack Replacement - Arizona
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by romad, Mar 19, 2022.
  1. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
    Has anyone had their battery pack replaced onsite in Arizona. I'm not talking about at a dealer.
    I live in Prescott and while there are aftermarket/independent shops in the Phoenix Metro area, I really don't want to drive 2 hours to drop the car off, drive back to Prescott, then back to Phoenix to pick the car up. That is 8 driving hours and requires two cars.
    I've found two companies that say they come to your location:
    https://hybrid2go.com/product/toyota-prius-2nd-generation-2004-2009/
    2004-2009 Toyota Prius Hybrid Battery | Green Bean Battery
    Has anyone (particularly in Arizona) used one of these companies to have the Gen 2 battery pack replaced?
  2. JC91006
    16,928
    8,637
    Ask Steve if he’ll come to you. He’s in Phoenix
    Phoenixhybridbatteries.com
    srellim234 likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,783
    2,496
    Durham NC
    I have a green tec in one car I guess it’s rebuilt battery . At the price points it seems things are cleaned up a bit and put back into service . For that 7 to 950 plus cash I’ll add till l get to the 13 or 14 hundred and try n get It correct . The original Toyota battery made 20 years. At least mine did
  4. PriusCamper
    PriusCamper Senior Member
    13,372
    5,404
    Pacific Northwest, USA
    Most battery pack rebuilders are doing it mobile... But Toyota doesn't sell OEM packs to these folks, but DIY is easy. It takes a couple hours or less to swap out a pack once you've done it a few times; but way, way longer the first time. Regardless, any reasonably skilled car nerd can learn how to do it. Maybe you know someone? Friends you can ask to help you out?
    Some Prius packs are more difficult teachers than other Prius packs,
  5. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    I used GreenTec for a Camry hybrid pack years ago. No problems quick service
    However you may want to compare prices these days. OEM prices and aftermarket are converging. I’d go OEM any day over aftermarket if prices are similar.
    Greentec shop has one located in Phoenix
    Hybrid Battery Repair Shop in Phoenix | Greentec Auto
    PriusCamper likes this.
  6. Another
    1,819
    520
    Naples, Florida
    I forgot to mention that GreenTec makes house calls, not much $ but not for free.
  7. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    Steve Keith does mobile, not sure if Prescott, but give him a call. Some links to his discussions on PriusChat.
    PHOENIX HYBRID BATTERIES
    Quantitative Results of Grid Charge/Discharge | PriusChat
    How to test HV battery state of health on your Gen 2 (answer) | PriusChat
  8. Another
    1,819
    520
    Naples, Florida
    When I used Greentec the Camry was in Tucson and could have had them come out to change it but opted instead to drive up to Phoenix and get it installed at their shop. You make an appointment and can wait for it to get done. Used to take a couple of hours. The prices for Greentec new cell refurbished packs has increased of late by 30%. They make quality packs but I think I’d go OEM if a Toyota shop would deal on it.
  9. romad
    320
    57
    Prescott, AZ
    Even if the Toyota dealer would meet the price for the battery pack, their outrageous labor rates are a deal killer. I looked at GreenTec but there is the back and forth to Phoenix which I'm trying to avoid. Right now, the Hybrid2Go looks the best but was hoping someone had used them or Green Bean Battery.
    Yes, I could probably do the swap myself but it would be the first and only time, so I figured it would be best to use an experienced technician. Plus, then I don't have to pay the core charge plus shipping to get the old pack back to them.
  10. Another
    1,819
    520
    Naples, Florida
    Greentec makes house calls
  11. Another
    1,819
    520
    Naples, Florida
    GreenBean is crap
  12. romad
    320
    57
    Prescott, AZ
    2 hours outside the Phoenix Metro area?
  13. romad
    320
    57
    Prescott, AZ
    Can you clarify? What problems did you have with their battery or service?
  14. Another
    1,819
    520
    Naples, Florida
    They routinely drive to Tucson which is almost two hours
  15. Another
    1,819
    520
    Naples, Florida
    They recycle used cells, not install new cells. Greentec offers both recycled used cells and new cells options. But like I said, their prices have increased substantially this past year, making them closer to OEM. All depends on how long you intend to keep car. Short term then go cheap, long term go OEM if you can afford it. Greentec is an option in between but you have to shop around. They will give you a firm quote if you call.
  16. romad
    320
    57
    Prescott, AZ
    OK, I may ask Greentec for a quote with installation up here along with quote from Hybrid2Go. It is more short-term as the car is 17.5 years old now (as is the battery!).
  17. Another
    1,819
    520
    Naples, Florida
    I think greentec and hybrid2go are the more pricey options for more than short term. All depends on what you mean by short term
  18. romad
    320
    57
    Prescott, AZ
    Greentec & Hybrid2Go are so far the lowest priced I've found at $1250 & $1199 respectively before tax. The install charge if any may be the determine factor.
  19. JC91006
    16,928
    8,637
    That’s almost price of new
  20. romad
    320
    57
    Prescott, AZ
    No, new ones are in the $2K area from Greentec. I've sent an email to my local dealer parts department asking the price of a new OEM battery; hopefully when they open on Monday I'll get a response.
