Battery Pack Replacement Options
Discussion in 'Gen 3 Prius Main Forum' started by dkichline, Aug 28, 2018.
  1. dkichline
    dkichline New Member
    Reading, PA
    I have a 2010 Prius with over 160,000 miles on it. I got the triangle coming up and the engine codes are C1259, C1310, and P0A80.
    So I am looking to replace the battery pack, but I am not sure what the best avenue for this is. I could go to the dealer, but if they charge a similar price like they do for their air filters, it is not worth it.
    I saw this Green Bean battery online, where they will come to you and replace the battery. They have been around for awhile, but I have not seen any definitive reviews outside of their site. I saw a few threads they were talking in, but no follow up on their product.
    I am in the Reading, PA area. Are there any options that people are aware of for local shops that do this type of work?
    Thanks!
  2. PriusCamper
    PriusCamper Senior Member
    11,093
    4,515
    Pacific Northwest, USA
    First step is to make sure you have a healthy 12volt battery and that your Hybrid Battery cooling fan is not clogged... If the red triangle just came on and you took that warning seriously and haven't driven it much since then, it may be fixable on the cheap side of things via first steps I mentioned, or by reconditioning battery pack, maybe even replacing a module or two, which becomes problematic if the battery pack is too far gone.
    The good news is that Toyota dealership decided to compete with after-market Hybrid batter sellers / refurbishers and you can get a new stack of battery modules for as low as $1950 if you install yourself and + 5 hours labor if they install. If you go this route you won't have to think of your battery again for 5+ years or longer... That's not the case with module replacement or aftermarket sellers / refurbishers.
    Bay Stater and kenoarto like this.
    49,445
    welcome!
    the key question here is; how long do you plan on keeping your car?
    only a new battery will give you virtually guaranteed longevity.
    otoh, if you sell it, a new battery will also increase the value over rebuilt.
  4. thehybridguy
    thehybridguy New Member
    Dallas
    I have also not seen much of them outside their company. Something to think about identity what will they do when the battery fails. All batteries fail its a matter of when, not if. If it takes them 5 weeks to replace a warranty is it worth it?
  5. golfmk681
    golfmk681 Active Member
    262
    105
    los angeles, ca
    I got a used 2016 battery, much cheaper than new.
  6. PriusCamper
    11,093
    4,515
    Who made the battery? The challenge with Prius is 12 volt battery doesn't start the engine, the high voltage hybrid battery handles that, which is why loads of con-artists, especially Optima, sell reject 12 volt batteries to Prius owners and they have no idea how bad their battery really is. Best bet for Prius 12volt is the most common and fastest selling 12volt wheelchair & backup computer power supply battery they sell at Batteries plus and other places for $130. Not only is it $100 cheaper than lower quality battery sold at auto parts store for Prius, but it's a much stronger longer lasting battery so if you leave headlights on or interior lights on for too long, it doesn't matter as much.
  7. bdonley
    bdonley New Member
    San Luis Obispo, California
    Any wiring mods or spacers to be made so it'll fit? Got a part Number? Thanks, Bill D
  8. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    A junkyard battery from a Gen 4 (2016 & newer) Trim One or Two ONLY (not Two ECO) is a NiMH battery whose modules will work in a Gen 2 or Gen 4 Prius. The other Trim levels (invluding the Prime) use a completely different battery type.
    @2k1Toaster has another good option if you are DIY. He sells a kit of new cells for $1600 delivered that basically gives you a new pack. You are free to sell any of your old modules that have not yet failed. The link to his site is in my signature.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,909
    Columbia, SC
    Hydrogen sulfide inhalation killed mother, toddler found on Florida's Turnpike in June - Orlando Sentinel
    When an OEM Toyota 12v battery will typically last 6 or 7 years, you have to ask if it's worth it to not install the correct vented style battery. If this happened to someone you care about, how would you feel about saving that 100 bucks.....is the risk very minute? sure, but the price is immeasurable...............
    I'm a major DIYer and I'm all for unique solutions to problems, but I have my limits.
    #9 TMR-JWAP, Aug 29, 2018
    Prodigyplace likes this.
  10. Mendel Leisk
    38,709
    So you're not going to bother? :confused:
    I would, and contact every dealership within driving distance. Let them know you're asking them all. A new hybrid battery through dealership is the best for longevity/reliability I think.
  11. hill
    8,172
  12. Prodigyplace
    11,696
    11,318
    Central Virginia
    #12 Prodigyplace, Aug 29, 2018
    hill and PriusCamper like this.
  13. Gergo
    Gergo New Member
    Swords
    Hello guys. Few weeks ago i got a fault message on my Prius P0A80. First time the program showed me Block 7,8 was faulty so i replaced them. Then i start use the car again and several hours later i got the same message but this time the diagnostic showed me Block 10 got some problem so i replaced it as well. Today i got another P0A80 but now Block 4 got i'm gonna blow my mind. Anybody have some solution?
  14. hill
    8,172
    Sometimes you have to hold people's hand and even provide a link but yea ...
  15. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    If that doesn't work, you have to hand feed it to them.
  16. Prodigyplace
    11,696
    11,318
    Central Virginia
    Grit and ITBland like this.
  17. Exiled conservative
    Exiled conservative Junior Member
    30
    Whittier, ca
    What was the price and for a Gen 3?
  18. golfmk681
    262
    105
    los angeles, ca
    It’s was $1300 installed. Includes taxes. Had abou 22k miles on it.
  19. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Welcome to the wonderful world of "whack-a-mole".
    You may want to start your own thread.
    Sounds like your battery is failing and this is going to be your life for now. Keep doing it as long as it is fun for you. Else you may want to get a new or warrantied battery.
    Any chance you accidently left the bad modules in and simply moved them around?
  20. PriusCamper
    11,093
    4,515
    There's lots of things you can do to avoid the worst aspects of "whack-a-mole." The data you get from discharging and recharging modules is key... Some cells within a module will show more heat or not enough heat, some modules will drop a cell during discharge and if you don't look closely enough you won't realize it's a bad cell, but just a weak module. Conversely, some modules may seem bad but after a 3 or 4 rounds of discharge and recharge it can end up being the healthiest one of the bunch.
    Some key pieces of equipment you need are high quality bluetooth OBD2 reader that can read data real fast, as well as grab subcodes. Veepeak is the one I use after an insane amount of online purchases turned into returns/refund. Also the Dr. Prius app, the Hybrid Assistant app, the Hybrid Reporter app. Also 12v 50w and 100w bulbs for load testing and discharging modules, kitchen timers and lots of multi-testers/volt meters to observe the charges and discharges in real time. A laser temp reader or a thermal imaging camera can help find overly hot or cold cells. As for chargers you need some quality RC smart chargers for individual modules, like SkyRC B6AC V2, as well as a charger & discharger to do the whole battery pack at once like the one hybridautomotive.com sells.
    I learned this Summer the hard way that this kind of work is for people who like to be overly-thorough and do everything possible to ensure that they don't have to pull the battery pack out again. Another crucial skill is how fast you can pull out and put back in a battery pack. Once you get good at it, you'll be able to have the battery out and on the work bench and all the bus bars off and ready for testing in 20 mins, with maybe a little more than double or triple that time to put everything back together.
    Do all this and "whack-a-mole" isn't so bad anymore...
    Cyvan likes this.
