Battery Power for Lawn equipment -- is it time?
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Jan 24, 2018.
  1. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    ^^^ that is exactly the situation I am trying to prevent. That's why I nearly always default to electric tools, though not always cordless. I maintain 3 small engines, and that's enough thanks!
  2. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    The post implied that buying anywhere else but greenworks.com voids any warranty but it turns it he got his tool from eBay. If you purchase from any authorized retailer (Lowe's, Costco, Tractor Supply, etc) you still get the warranty. It is kind of crappy they don't offer a transferable warranty. Unfortunately those limits aren't uncommon these days. And I suppose it can make sense if they're concerned about using residential tools for commercial purposes (of course you could help yourself a bit better by not slapping "pro" stickers on your residential 60v and 80v product lines...)
    So far I've been quite impressed with the 60v tools and riding mower. I got the 16" chainsaw this week and it did great on a fallen down maple in my yard. Cut the whole thing up into 2' logs and trimmed the branches in less than an hour all on a 2.5a battery. My echo 14" gas saw struggled with just the thicker branches.
  3. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    10+ years ago, I don't think there was any electric power washer affordable that could do the job required. I paid ~$300 for it then IIRC. For the same cost, I can now get a more powerful and fuel-injected plus throttled gas-powered power washer. I just checked Home Depot for an electric power washer. The only one that exceeds the spec of this 10+ years old gas-powered RIGID power washer with 3000 psi, 2.6GPM is this one.
    DEWALT3000 PSI 4.0 GPM Electric Cold Water Pressure Washer with 208/230V Induction Electric Motor
    No, I am not going to buy it for the cost of $2899.
  4. hill
    8,810
    Power washers that are designed to run cold water through them - I wonder if any can handle picking up hot water out of a utility sink. Would love to be able to hot water wash salty sludge off the bottom of the car in winter time before pulling into the garage, where sludge drips onto the slab, freezes, & destroys the integrity of the slab.
  5. Salamander_King
    11,019
    8,954
    New England
    As long as your tap hot water is not exceeding 140F, using "warm" water in a cold water power washer should be fine. I don't own or never used a hot water pressure washer. I know they are very expensive. And as I understand it the hot water pressure washer heats up the supplied cold water all the way to 311F in the machine before spraying it. Yeah, that temp is higher than the boiling water, meaning it is pressurized high temp water.
    I have installed a hot-and-cold frost-proof faucet on the outside wall of my house several years ago. I have used hot water out of this faucet feeding to my cold water pressure washer many times without seeing any ill effect. Our home domestic hot water heater is set at 120F, so the hot water out of a faucet is less than that temperature. According to this article and many others, I've Googled, it is fine to use "warm" water up to 130-150F in a cold water pressure washer.
    Source: Can you use hot water in your pressure washer? – Garden Tool Expert
    Can you use hot water in an electric pressure washer?
    You must keep in your mind that hot water pressure washers are specially designed for use with hot water only. A cold water pressure washer simply can never handle hot water. Most of these can only work with a water temperature of one hundred and forty degrees and below.
    #665 Salamander_King, Jun 21, 2022
    hill likes this.
  6. Stevewoods
    Stevewoods Senior Member
    659
    1,136
    Seattle, WA
    Greenworks chainsaws for 25 percent off at the company website. Use code king25
  7. bisco
    51,968
    still loving the ryobi rider. of course, it's only year one
    Zythryn likes this.
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,467
    2,434
    Taylors, SC
    My third year with the Ryobi riding lawn mower. The meter is junk and not working. It doesn't mater, however, because I have the 100 AMP model and my lawn is only a third of an acre.
    I bought the 100 AMP model, because lead acid batteries have longer lives if they are never close to completely drained. Mine never gets drained bu even 40%.
  9. Trollbait
    12,543
    They went with Li-ion recently.
  10. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    A 50cc 2-stroke (2.5hp) backpack blower at best only move 600 cubic feet of air per minute. That's just enough to clear a walkway. Trying to clear a lawn with that is like spitting in the ocean. Leaf blowing on a lawn starts at 7 horsepower and you go up from there. That would be about 2000 cubic feet per minute of air movement. Getting something too small is a waste of your time and your time is worth more than the device. Here's a video that compares them so you can see it for yourselves. I have a postage stamp property and I have a seven horse ground blower just to clear the front yard
  11. Stevewoods
    659
    1,136
    Seattle, WA
    I have an assortment of Greenworks products. All bought at steep discounts around this time of year. I have gas chainsaws -- if i did not i might consider the GW offer. But Stihl gas is my saw of choice -- as much as gas can be a PITA.
  12. 3PriusMike
    3,100
    2,419
    Silicon Valley
    For that many leaves, maybe a rake?
    But if you really want to just blow them, how about a helicopter?
    Mike
    Todd Bonzalez, Trollbait and Zythryn like this.
  13. bisco
    51,968
    mine only goes down a bar or two after an hour. is that because it is inaccurate?
  14. douglasjre
    2,181
    720
    Null, NL
    Raking my front yard takes one person 7 hours. Even with gloves you will have blisters and mosquito bites and regret the whole experience instantly :)
  15. Georgina Rudkus
    3,467
    2,434
    Taylors, SC
    The Ryobi tool outlet are having a 40% sale on all NEW "factory blemished" and 50% of on all refurbished tools.
    If you are looking for lawn equipment, it might be the time to buy.
    If you don't have an outlet store near you, right now shipping is FREE.
    Direct Tools Outlet Site
  16. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    Thank you.
    I was overdue to replace several small electric tools and this hit the spot!
    $54 instead of $90? Deal. I nursed the old one along for 14 years, can't even get the right battery anymore.
    (I couldn't find this one in a set, had to order the battery & charger separate, but they were 40% off as well)
    #676 Leadfoot J. McCoalroller, Jan 28, 2023
  17. Salamander_King
    11,019
    8,954
    New England
    Did you check HomeDepot?
    RYOBI ONE+ HP 18V Brushless Cordless Compact 1/2 in. Drill and Impact Driver Kit with (2) 1.5 Ah Batteries, Charger and Bag PSBCK01K - The Home Depot
    This kit contains the same compact HP drill mentioned in your comment. Yes, the kit is $129, not $54, but contains a compact HP impact driver ($99 tool only but can buy at $89 as a single tool kit with a battery and charger and bag), two 1.5ah batteries ($69/each if purchased separately) and charger (~$30), and a carrying bag. If you don't have an impact driver already, it is a must-have hand tool. I use it far more often than a drill. I use to use the drill as a driver and always ended up stripping the screw heads. With an impact driver's slow RPM high torque, it is designed to drive the screw better than a high-speed RPM drill.
    Home Depot may even have a better deal in a few weeks for the President's Day sale.
  18. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    No, I really prefer not to do business with them so it didn't even occur to me to check.
    Salamander_King likes this.
  19. Salamander_King
    11,019
    8,954
    New England
    You will miss great deals if you avoid dealing with the big box store. But I guess, you have your priorities. I understand. But especially for Ryobi tools, IMHO, there is no other place you can get a better deal than Home Depot. I basically get free batteries from them every year when they have a sale with free tools or batteries with a purchase of a kit. I buy a kit and get to choose a free tool or extra batteries and return the kit I don't need... keep the free battery or tool. This is completely legal going by their return policy.
  20. Georgina Rudkus
    3,467
    2,434
    Taylors, SC
    Rather than getting the bare drill at $54, I'd get this set.
    These are the same kit with two different prices. This is the current SPECIAL BUY at Home DEpot for $89.99.
    This is the regularly packaged kit selling for $129.99 at Home DEpot.
    Packaging is the only difference.
    I bought the first one,
