Battery Power for Lawn equipment -- is it time?
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Jan 24, 2018.
  1. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    I forgot to add that I also have the corded Oregon CS1500. Works great for my needs. However, if I was on a heavily wooded lot, or owned land in the woods, I would most certainly go with a hefty gas powered model, as you did.
    Anyway, my point is that electric chainsaws work perfectly fine for the average homeowner.
    Zythryn and Mendel Leisk like this.
  2. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    The heavy is in relation to the battery pack it comes with it. Most battery operated chainsaws I checked use 40-80v single pack. And total weight with battery is less than equivalent power gas engine models with fuel. But, yeah, if they can make powerful enough battery chainsaw as today's 80cc and above gas engine model chainsaw, they may have to have more than a single pack of battery, that would make it heavy. Or, maybe they can make it with external battery pack with a cord, like other battery powered yard equipment.
    #922 Salamander_King, Oct 15, 2024
  3. Salamander_King
    11,019
    8,954
    New England
    Agreed. Of course, I suspect most average homeowner probably can do without any chainsaw. If you have no three to cut... or only small shrubs, a hand saw will serve fine.
    farmecologist likes this.
  4. Trollbait
    12,543
    Battery power supplies do exist. With a larger property, I'd look into getting one that would fit into an old backpack, and making a 3 foot extension cord. Doesn't help the power issue, as corded outdoor tools are limited by the 15a 120V outlet.
  5. hill
    8,811
    A 12 gauge extension cord can handle a 20 amp draw. Why in the world contractors don't put more of these bad boys in is a mystery.
    That will give you an extra 20% 25% greater power capability
  6. John321
    John321 Senior Member
    1,457
    1,405
    Kentucky
    The answer is cost, 20 amp requires a larger wire gauge which will result in a little extra cost - but well worth it in a garage.
    In most cases a 15 amp circuit breaker and a 20 amp circuit breaker cost close to the same amount and so in most cases would the associated outlets
  7. Mendel Leisk
    41,488
    Is the outlet pictured in post #925 upside down? Just curious.
  8. ChapmanF
    18,242
    Welp, now you've stirred it up ....
    "nema 5" upside down - Google Search
    Often, if you look at the factory printing on the receptacle, you'll find it oriented as if the picture above is right-side-up. But everybody's pretty much used to seeing them the other way.
  9. Mendel Leisk
    41,488
  10. ETC(SS)
    7,171
    I'm not an electrician, and I don't play one on TV, but most (probably NO) 12AWG extension cords are rated for 20 ampres.
    Blame lawyers, because the copper doesn't really care about people's 'feels.'
    The actual, real-world, lawyer-free ampacity for 12AWG wire is MORE than 25 ampres, but it's probably illegal to point that out in print without a paragraph of "you're gonna DIE HORRIBLY, SCREAMING IN AGONY" disclaimers.
    A 10-gauge wire is 26% larger than a 12-gauge wire in cross-sectional area according to the googles, and the resistance delta is something like 0.6 ohms in the first thousand feet. (solid, room temp, and DC for the budding EEs - and yes.....60 Hertz is close enough to DC)
    SO...
    Most of the additional costs for that fancy schmancy NEMA-5 stuff isn't for the copper.
    You know....the part that actually conducts the electricity!
    To be fair - the sheathing is pretty important too, which is where the additional money is probably spent, along with 8 figures of liability insurance
    If you need a 120v 20-ampre motor for a piece of lawn equipment then you might want to consider an ICE alternative.
    -just sayin
    #930 ETC(SS), Oct 18, 2024
  11. ChapmanF
    18,242
    Strictly speaking, it's not the copper that has an ampacity, but the wire: the copper, the insulation around it (which has a certain temperature rating and a certain ability to conduct away heat), used in a particular setting (surrounding temperature and ability of surroundings to carry heat away). That's why ampacities given in the NEC are different for wires with different insulation types, and different for run in free air vs. in conduit with other wires, and so on. (If you have an old house with knob-and-tube wiring, blowing insulation into the walls is a no-no, because those wires were rated for free air.)
    Observing the wire ampacity will make sure the wires don't get too hot for their own insulation—assuming the cord is used in the right conditions (not still coiled up, not running under carpet, etc.).
    A separate issue is how much lower the voltage will be at the far end of the cord. That also needs attention, and that depends on the amps, the gauge, and also the length, so a gauge that's adequate for so many amps in a ten-foot cord will be too skinny in a fifty-foot cord.
    Extension Cord Size Chart - Understanding Wire Gauge and Amps - PTR
  12. ETC(SS)
    7,171
    That's why I don't play an electrician on TV.
    The point about the wire/cable/cord is an excellent one.
    The NEC is rather like State Troopers - even down to the revenue generation.
    HOWEVER (comma!!!)
    Since I'm older than 2020, I understand what happens to the interstate system when state troopers stay locked in their barracks. ;)
  13. Stevewoods
    Stevewoods Senior Member
    659
    1,139
    Seattle, WA
    Wayback in August, the wife insisted lawn needed dethatching
    I popped open a Hamms, said "No," and went back to the giants game.
    Of course, lost the battle and dethatched in the fall.
    Point of tale is I looked for a quality dethatch rake -- $70. For a rake??
    Poked around. Found Greenworks running a deal for a corded dethatcher for $100 USD, FREE ship.
    It's a sort of puny thing, but it did a great -- fairly easy-- job. Cord was really not much of a bother.
    Seeded it back in the fall and the lawn has come back looking great.
    So, first of all, don't overlook corded equipment. Battery machines were at LEAST double the price and a lot more.
    Second, I know she's going to win the battle, why bother trying.
  14. bisco
    51,973
    i've finally worn mrs b down to the point where she calls contractors rather than asking me
    ETC(SS), cyberpriusII and Stevewoods like this.
  15. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    You answered your own question. You (theoretically) paid for quality.
    A rake that doesn't break, leave splinters or chemicals in your skin, and actually de-thatches the grass without overly fouling or clogging itself, has good strength and balance, doesn't hurt too bad after you accidentally step on the business end of it... there are many ways to rate quality in rakes, but like all tools the good stuff tends to be worth it.
    cyberpriusII and Trollbait like this.
  16. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I also use a corded dethatcher and it works well (as does my corded garden tiller). I also have a core aerator (a rollerator for about $300) which gives me quite a workout. It weighs about 50 lbs. and it takes me a few days to aerate my 6000 sq ft lawn. I do get positive comments on my lawn each spring.
    JeffD
    bisco and cyberpriusII like this.
  17. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    Just touching this thread with an update.
    I'm not traveling quite as much this year, and the mowing company I used last year seems to have gone ghost.
    I found somebody local who deals in old lawnmowers. He had a 40 year old Bolens rider on hand that nearly matched mine. I did a deal and traded in my broken down one for this other one. It's actually a little older but it has a few nice options that my previous one didn't. Everything I learned about operating and repairing that first one has been useful.
    It's noisy and stinky but it gets the work done.
    With the current political outlook I think an electric riding mower just slid a few years further into the future if it ever happens. :(
  18. bisco
    51,973
    have they gone up in price already?
    this is only a few hundred more than i paid for a lesser ryobi model 3 years ago: 322306539
  19. Leadfoot J. McCoalroller
    8,092
    7,574
    Pennsylvania
    2018 Prius c
    1. Up is the wrong direction, especially for a product that recently emerged and seems to show sales growth.
    2. I'm not optimistic about spares, repairs and warranty fulfillment (should it become necessary)
  20. bisco
    51,973
    agree on repairs and warranty fulfillment.i had to replace the charger receptacle assemblymyself or somehow get it to home depot or an approved repair shop.
