Battery Power for Lawn equipment -- is it time?
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Jan 24, 2018.
  1. ChapmanF
    18,706
    or a vampire
  2. hill
    8,974
    Wow - That is one big motor - compared to our 3yr old 243cc engine on the Craftsman.
    Even this has no issue plowing through 16" drifts that we get. Our local Ace Hardware has a nice rebuild shop, so that's part of the reason we went with what we got. That, and parts of availability.
  3. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It turns out that you need 7HP or stronger to have a useful snow blower. My inexpensive 5HP tends to clog up in wet snow.
    JeffD
    ColoradoBoo likes this.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,297
    913
    Monument, Colorado USA
    I've only seen one negative review about my 389cc snow blower and that was that the guys liked to chew threw the two shear pins. So I'm wondering if the extra HP might be cause of that orif the guy was really giving her a hard push through some wet, dense snow?
    But I got extra pins so we'll soon find out...looks like snow here next weekend....not sure how much, yet....mountain weather is horribly unpredictable.
  5. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    Battery Chainsaw Humiliates The Best Gas Chainsaw!
    from Project Farm. His videos move right along - don't be afraid to stop or rewind multiple times
    youtu.be/u6FM_08066I
    batteries are 40 and 60 volts with amp hour ratings all over the place, but still a lot of good info, especially at the very end when he explains the difference in work load between the battery power and the gas power saws.
    I just got a second hand ryobi 13in 18v mower for the front lawn. it came is a 4 amp 18v battery and the little charger. I've already got 2x 9 amp 18v packs and the front lawn isn't big enough anymore (trees and garden) to use even use all of the 4 amp battery up. Maybe next year I'll update to the 20" mower or the " High Performance 12 amp 18v pack ", it's uge.
  6. bwilson4web
    16,422
    An unbalanced blade led my +5 year old, Greenworks mower to give up the ghost 10 days ago. So I replaced it at COSTCO with both a manufacturer's $100 rebate and $129 "Executive Membership" coupon, $395, about what I paid for the first one.
    It included two new batteries and an additional charger. Much improved with a second bin to hold a second battery. Also, optional drive wheels to handle going up a slope.
  7. Leadfoot J. McCoalroller
    8,170
    7,675
    Pennsylvania
    2018 Prius c
    If you don't mind, I'm curious what happened? I still have a greenworks mower I got secondhand in 2017, still runs great. Spare blade was only $20.
  8. bwilson4web
    16,422
    I had put a heavier blade on the mower and tried to balance it myself. But the vibration suggested it was not as smooth running as it should be. Lesson's learned.
    The original blade was abused by someone who didn't clean up objects in the yard but ran over them. My workaround, a heavier gage blade reduced the impact damage but it really needs to be balanced.
    I am keeping the old one and will strip it down to replace the bearings. Also, an object lesson for the other operator.
  9. Leadfoot J. McCoalroller
    8,170
    7,675
    Pennsylvania
    2018 Prius c
    I guess I feel better about the $5 I spent on a blade balancer. Good luck with the new mower!
  10. bwilson4web
    16,422
    Tuition in the school of "hard knocks." But at least there has been significant improvement in the mower and two new, high energy, batteries versus single replacements:
    • $83 - Walmart listed
    • $107 - Greenworks refurbished
    • $290 - Greenworks new
    The new mower has:
    • two blades in an offset, cross mount
    • carries a spare battery in the housing
    • powered wheels for going up a grade
    • much easier, whole deck height adjustment
    • sturdier handles without cheesy locking knobs in the middle
    • +5 years of operational and warranty changes to mower design
    #970 bwilson4web, Apr 22, 2026
  11. hill
    8,974
    Dang! If it weren't for the letters on those suckers I'd swear that was a ryobi. Both made in china. Maybe the same factory?
    I see the Green Works are now 80 volts. Wondering if that's all of them today - or or some still 40 volt.
    Looks like a nice buy, & a couple years from now if it croaks it's backed by Costco's great return policy
  12. bwilson4web
    16,422
    Costco sold the 80 V one +5 years ago and other than one infantile battery problem, a very nice tool set. However, I noticed they also sell as much more affordable (and less capable) 48 V one.
    I do use Ryobi hand tools: angle grinder; drill; nail driver, and; light duty vacuum. I've added a diamond wheel and chain blade disk. Good, products.
  13. jdenenberg
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Old geezer engineers like us should have learned that lesson a long time ago.
    "People say we should learn from our mistakes. I would rather learn from the mistakes of others. More lessons, less pain."
    Thanks for the lesson.
    JeffD
  14. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,522
    2,536
    Taylors, SC
    After 5 years, I just converted my Ryobi RM480ex 48 volt lead acid battery powered lawnmower to LiFePO4 for less than $500 including a new charger.
    Unlike the new 80 volt lithium ion models that use expensive $600-800 proprietary batteries only available from the original manufacturer, generic batteries are available from many manufacturers in the 48 volt category at highly competitive prices.
    Five years ago, theya were very expensive. Now, they are absolutely cheap.
    The conversion was absolutely easy.
    I will eventually post as a hew thread, because the conversion will work with many Ryobi riding lawnmower models.
  15. bisco
    52,524
    glad to hear it! I'll be looking for your thread. ours is still going strong, but I know the day is coming...
  16. Mendel Leisk
    42,041
    Trusty/rusty, corded Craftsmen here, at least 15 years old, was around $200 CDN
  17. hill
    8,974
    When I first saw "corded" I had a flashback to having to wrap the cord around the starter spool & pull, hoping to God I wouldn't have to rewind & try again. You kids got it easy
    bisco and Mendel Leisk like this.
  18. Georgina Rudkus
    3,522
    2,536
    Taylors, SC
    Ryobi realized that they made a mistake with the 48 volt lead acid riding lawn mower platform.
    They are easily and readily converted to LiFePO4 for $400-800 and will outperform the new models with expensive proprietary batteries costing $800-1000 and more.
    The new ones have sealed modules that make them difficult to repair.
    The old ones are simple and will easily last nearly 10 more years with the new improved batteries.
    The old ones are sold everywhere used dirt cheap with degraded lead acid batteries.
    So, if you are looking for an inexpensive battery electric riding lawn mower, the Ryobi 48 volt battery electric ones are the way to go.
  19. bwilson4web
    16,422
    Now if I could just get this in electric:
  20. hill
    8,974
    ....... once again proving all it takes is either time or money
