Battery power getting low mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by puppychew, Sep 11, 2013.
  1. puppychew
    puppychew New Member
    Hi - When the shaded area is in the battery half of the ECO bar I would expect to have the mpg be 100. It sometimes shows only 25 mpg. Just purchased a 2010 and learning how to get the best mileage possible.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I wonder why you would expect to get 100 MPG? Isn't it rated at 50 MPG?
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    If the ICE is running then your MPG reading may still be lower even if you're in the EV zone.
  4. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    When the power bar is below the midpoint, it is possible for the engine to stop and the car will run on the battery. When this happens, there will be an 'EV' next to 'ECO' above the bar, and the mileage indicator will go to maximum. Once the car has warmed up-usually a 5 minute (or so) process- and the battery has enough charge- generally 3 bars or more- the car will go into this EV mode when the power bar is below midpoint. This is mode is also called gliding. However, it is possible for the engine to run while the power bar is below midpoint (for a variety of reasons) and the indicated mpg's will be as you noted. With some experience, you will be able to control (somewhat) the several modes available.
    Note: do not confuse the EV mode on the system indicator with the EV mode available when you push the EV button on the console.
  5. puppychew
    Thanks, that makes sense. My mpg is 58.3 over 3 tanks of gas and I have been watching the indicator so I can stay at that. I guess I have to practice the glide mode better. Driving this way requires lots of concentration!
    thanks!
  6. bwilson4web
    16,490
    Instead of 'glide', just shift into "N" and coast. It is a lot easier with one caution. If you coast and the vehicle speed climbs over 42 mph, do a one second shift into "D" and back to "N" as a precaution.
    The older Prius had an MG1 rpm limit above the 42 mph and would increase the engine idle speed to prevent over-rev of MG1. But testing last week up to 74 mph did not show this still happening with the 2010 Prius. Just I'm a cautious sort of engineer and until we can get a good mapping of what is going on, recommend coasting in "N" above 42 mph with the engine running.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  8. puppychew
    Actually above the bar only ECO appears not EV. ECO lights up in green near the speedometer. It seems that I can have EV and ECO light up in green at the same time.
  9. dan2l
    dan2l 2014 Prius v wagon
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Puppychew,
    Yes, You are correct. the 2010 does not have an EV light to indicate that the ICE is off like the newer Gen3's. You really need a ScanGauge to see RPM and really know what is happening.
    Thanks,
    Dan
