Battery Problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KillJoy124, May 12, 2015.
  1. KillJoy124
    KillJoy124 New Member
    Hudson, NC
    I just got my 2004 Prius recently and I knew I was going to have trouble out of the 12v battery soon and I was prepared for that and when it first started I handled it well enough, I charged it properly and it was manageable for a month or two. At first I had to charge it every now and again and then every other day then every day but recently it has been going completely dead and charging it isn't helping. In the last few days I've had to boost it off with another car and it'll run but as soon as I turn it off it is completely dead again.
    I guess my question is if my problem is still just with the 12v battery or am I looking at having to replace the hybrid battery? I can replace the 12v batter but will that fix my problems?
    oh and I have having problems with my catalytic converter recently, I don't know if they are related at all but they both started to go at the same time. I am looking into having it replaced
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    52,854
    how many miles on her?
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    You have a very old 12 volt battery that no longer will hold a charge. You need a new one.
    This may not solve all your problems. BUT...it is one thing at least you need to do.
  5. Mendel Leisk
    42,345
    If you can get a hold of a digital multimeter, check and post what the voltage is, after it's sat overnight. If it's 12.6 it's fine. If 12.4~12.5 it's showing it's age but "ok". If 12.3, lower, it's losing the ability to retain charge.
  6. KillJoy124
    Hudson, NC
    About 175k miles
    I know that I for sure need to replace the 12v asap at this point but I just don't know if whats happening is also a sign of the hybrid battery going out.
  7. Mendel Leisk
    42,345
    If the hybrid battery was going you'd notice driveability problems, strange/sudden ups and downs of charge state and more than likely there'd be warning lights on the dash. Assume the best, replace the 12 volt first.
    Still, a digital multimeter, a $20~30 one will do for starters, is invaluable for battery status checks. Load testers are another level, but a multimeter is good. You can sort through all the questionable batteries in the tool drawer too. :)
  8. KillJoy124
    Hudson, NC
    I will be sure to make that investment while I'm also picking up a portable power pack/jump starter thing. ^.^ thanks for the suggestion because my only option to check the battery was to go to my local Toyota dealership I though and I have a strong feeling that it would only end in me reluctantly buying a new car.
  9. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    I doubt very much that you have HV battery issues, based on what you have posted, so in agreement with other posters on this.
    What intrigues me more is that you have posted information that clearly shows your 12 V is history, you seem to be of that opinion yourself, several others have posted the same, and yet you seem to be resisting changing out your battery for a new one.
    Please, TEM gives good advice:
    Once you have your new 12V battery installed, re-evalute and see if there remain any further issues.
    All the best.
    PS, I wouldn't bother buying a jump pack as well, because once you have your new battery installed, you won't need to use it for several years. Do buy a DVM, though, it has many other uses both around the car and home.
  10. KillJoy124
    Hudson, NC
    I haven't been resisting per say I just haven't had the means until now and now that I do I wanted to be sure that I wasn't sinking money into replacing the 12v if as soon as I do I find out that what I have been experiencing was actually the HV battery. I know that charging the 12v was helping but I didn't know the two weren't related until JimboPalmer commented pointing that out. After a few comments reassured me that it is the 12v I have came to the decision that I will take the step to replace the battery instead of trading in for another car.
    I mentioned the power pack because that was going to be my first step so I can make it to and from work for a week or two until I can get the battery but now that I finally looked it up I don't think I'm going to bother and try to make time to just go straight to get the battery replaced. Thanks for pushing me to looking it up to get a price before I walked into that blindly. I will still get the DVM.
  11. bisco
    52,854
    no, it's not. no symptoms you've mentioned so far have anything to do with the hybrid battery. the catalytic converter is something that should be giving you trouble lights and codes, not 'problems'.
  12. KillJoy124
    Hudson, NC
    Well problems being a really strong sulfer/rotten egg smell and a maintenance required light
  13. bisco
    52,854
    then you need to take in for a code scan, to identify the issues and solutions. but neither relates to the hybrid battery. if concerns about the hybrid battery are keeping you up at night, you probably shouldn't have purchased an 11 year old prius with 175,000 miles.:)
  14. KillJoy124
    Hudson, NC
    After I have the battery replaced and it turns on without having to be boosted I will probably have it check with the catalytic converter fixed, I didn't buy it before I had done my research and a place ready to replace the hybrid battery when and if I needed to for a reasonable amount, I just expected a little more time to save up to replace it but thankfully that isn't my issue yet and maybe not for a long time considering a friend of mines Prius has gone over 300k on the original hybrid battery
  15. Mendel Leisk
    42,345
    Maintenance required light is just a dumb mileage counter, I think. It comes on, you consult the book as to what's need, ie oil change, get it done, reset the light.
    The egg smell could be the catalytic converter (as you're suspecting). I learned that all of 5 seconds ago, lol:
    Why does my car smell like rotten eggs? - Richmond DIY Auto Mechanic | Examiner.com
  16. KillJoy124
    Hudson, NC
  17. bisco
    52,854
    i wish you all the best my friend!(y)
  18. KillJoy124
    Hudson, NC
    I really appreciate everyones advice here, it was my decision to buy a prius (honestly my dream car) against my families and friends doubts. I felt confident in my decision because I did my research and this community has been my go to source for information. This being my first time asking my own question has been so much help. Just thanks so much ^.^
    dolj and Mendel Leisk like this.
  19. dolj
    dolj Senior Member
    8,645
    4,396
    It could also emanate from your 12 V battery, if one (or more) cell has failed.
    Like you said, fix one thing at a time and see how it goes.
    All the best.
  20. Jim Porta
    Jim Porta Junior Member
    86
    17
    Louisville, KY
    The second thing to do is get an oil change and reset the Maintenance Required light.
