Battery Question
Discussion in 'Gen 2 Prius Technical Discussion' started by bkcriz20, May 24, 2017.
  1. bisco
    52,614
    what are these batteries with all new cells? i don't recall reading about them, except for the program at toyota dealerships in california.
    what is bumblebee?
  2. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    52,614
    thanks. they are talking 'memory effect' of refurbished batteries, and quoting places like auto trader, and autos.com. it already sounds like they don't know what they're doing.
    seems more honda oriented.
    lists one prius battery good for model years 2004-2012.(n)
    they're claiming better performance than a new toyota battery due to proprietary technology.
    or, they have 'remanufactured'.
    $2,400. after core credit? plus installation? meh, i'll stick with an oem.
    #43 bisco, Jun 15, 2017
  4. dolj
    dolj Senior Member
    8,621
    4,376
    Wellington, New Zealand
    @ericbecky said he knows the chap that runs it and says he is a stand up guy who knows what he's doing.
    Yes, these batteries are true remanufactures and use a different cell tech to that used by Toyota.
    #44 dolj, Jun 16, 2017
    srellim234 likes this.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,450
    3,358
    Madison, Wisconsin
    Bumblebee is a company run by Eli P. Great guy. Quality packs. He has a high attention to detail.
    He has been a part of the hybrid community for a long time. Initially his business was heavily skewed toward Honda hybrids.
    New cell packs can be made with cylindrical cells instead of prismatic.
    I trust him and products from his company.
    Raytheeagle likes this.
  6. bisco
    52,614
    do you agree with the 'memory effect' of rebuilt batteries?
  7. ericbecky
    4,450
    3,358
    Madison, Wisconsin
    In my opinion saying "memory effect" is kind of simplification of terms for things that are more complex than that.
    There are some good technical papers I have read in the past that are much more detailed.
  8. bkcriz20
    bkcriz20 Junior Member
    53
    Queens
    So I recently had my Hybrid battery installed and I notice on the energy screen where it show the battery level of charge hasn't really fully charge yet.
    I've had the replacement done on 6/13 and I haven't notice it with a full charge, the most I've seen is around 6-7 stripes. I've also notice that battery has gone all the way done to 2 stripes here and there.
    Does this show that my battery is NOT a new battery?. Are these normal for a New battery?. What should a new battery show on the energy charge screen?.
  9. dolj
    dolj Senior Member
    8,621
    4,376
    So when you say "new" battery, you mean a new Toyota HV battery supplied and fitted by Toyota, or do you mean new to you but a recycled/refurbished second-hand HV battery such as Dorman, Greenwich, etc.
  10. bkcriz20
    53
    Queens
    Sorry for not specifying, I meant New Toyota Hybrid Battery supplied by a Toyota dealershipz.
  11. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Situation normal. The easiest way to see a full battery indicator is to drive down a mountain. Get stuck in line at one of the tunnels and you'll see 2 bars and the engine will spin up to recharge the battery to just above the minimum.
    Moving Right Along and bkcriz20 like this.
  12. Moving Right Along
    Moving Right Along Senior Member
    735
    591
    Agreed. I've seen my battery gauge completely full only once so far in the 6 months or so I've owned my car. That happened when I was coming to a stop after going down an hill. And it will go down to 2 bars when I've got the air conditioning on and stuck in traffic. The "happy place" of the battery is 6 bars, and most of the time, mine is at 6 or 7 bars.
  13. ericbecky
    4,450
    3,358
    Madison, Wisconsin
    While the screen is kinda interesting it doesn't give you the granular detail your really want/need.
    Kind of like a temperature gage with with "bars" but no actual numeric markings.
    You can buy inexpensive OBDII reader and pair it with Torque Pro app. Then you can set up much more detailed screens so you can see the numeric value of the State of Charge as well as battery voltage.
    bkcriz20 and srellim234 like this.
