Battery Recharge Voltage & Amperage..
Discussion in 'Gen 2 Prius Technical Discussion' started by AnailizeR, May 15, 2008.
  1. AnailizeR
    AnailizeR Junior Member
    57
    US - Somewhere....
    I would like to know what is the voltage and amperage used to charge the prius battery? Does anyone know?
  2. tochatihu
    tochatihu Senior Member
    8,995
    3,507
    Kunming Yunnan China
    2001 Prius
    Little PbA battery: nominal 13.8 volts, max 4 (or so) amps
    Big NiMH battery (2004 onwards) Nominal 202 volts, max 80 amps. But if you are talking about extended charging, much less than 1 amp. Doing *anything* to the NiMH battery requires unusual knowledge and skills.
  3. problemchild
    problemchild New Member
    429
    36
    Actually it charges at 14.8 volts.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    No, it charges at either 13.8 to 14 V depending on how much
    charge it's drawing, or reduces down to 13.6 in certain temp
    ranges when you shift to D or B per the VLO output from the
    hybrid ECU. The system tries to be more compatible with the
    known float voltage differences appropriate for PbA in different
    ambient temperatures.
    problemchild, please check the voltmeter you used against some
    other reference.
    _H*
  5. richard schumacher
    7,663
    1,038
    United States
    So it never applies a fast charge to the 12V battery?
  6. Patrick Wong
    18,199
    6,464
    Hi Richard,
    No. The battery is just connected to the 12VDC bus, and the main purpose of the bus is to power the various ECUs, the stereo system, the lighting, and other accessories requiring 12V power. Hence the voltage on the bus is tightly regulated.
    With a conventional automobile, the voltage produced by the alternator will increase somewhat as engine RPM increases. Hence if the 12V battery needs charging, the usual advice is to drive the car around for a while to allow a quicker recharge.
    With Prius, since the 12V bus voltage is held relatively constant, all that is necessary is to make the car READY and leave it alone if the battery needs to be recharged; there's no need to actually drive the car.
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, actually the 12V battery is "fast charged" sort of. My simple mind is boggled by how it works, but I left my amateur radio on for 5 hours last weekend by accident (more than 1 Amp draw) and noticed the 12V system voltage rose to 14 V when I started the car. It usually sits at 13.8 V. So a circuit that puts out more voltage when it sees a draw of more current is rather unique.
    I say "fast charged, sort of" because it raised the charge voltage when it noticed the current draw was higher. This results in higher current still, which results in faster charging. It's not a traditional "fast charge" (20-40 Amp type) which would be undesirable for the deep discharge small capacity battery we have in the Prius.
  8. AnailizeR
    57
    US - Somewhere....
    So... ~202 on 1.0 amps... ?? Thanx.
  9. tochatihu
    8,995
    3,507
    2001 Prius
    How 'bout 0.2? Prius HV battery assemblies have been damaged or destroyed by enthusiastic charging. When the car does it there is temperature monitoring and active ventilation. You sure you want to do this stuff?
