Battery reconditioning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by robert Kwasny, May 21, 2024.
  1. robert Kwasny
    robert Kwasny Junior Member
    35
    so cal
    Reconditioning my 2005 Prius battery again. after running five cycles on several modules I get numbers like this or similar to this with several charge numbers that are low. Wondering if I should toss those. Any comments or suggestions would be appreciated
    Dc. Ch
    3264-7647
    4948-7750
    5141-1001
    5054-6011
    5506-965
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,108
    2,008
    NJ-USA
    Using a RC hobby charger to determine module capacity is a bit of a guestimate. Use the discharge value, as that sort of measures the "actual" voltage and amperage that is leaving the battery.
    The charging value measures what's leaving the charger- you have no idea how much of that is being converted into waste heat in the battery.
  3. robert Kwasny
    35
    so cal
    Thank you I also have some modules that max out at 7500 milliamps on the charge cycle. Would that be an indication of a good or bad module?
