Battery Replacement - Economy Method
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vertex, Aug 4, 2009.
  1. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    I guess I do too much risk mitigation at work, so at home, I take the opposite approach. ( I design medical equipment, some risk, and plenty of mitigation). I will keep my eye on the battery though, but then again I am only one data point, so the statistics aren't meaningful.
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Just reading this for about the third time. I like this reply !
  3. vertex
    670
    143
    new york
    2018 Prius Prime
    I've been using the battery for over a year now, still A OK.
  4. FlyboyTR
    FlyboyTR Member
    86
    56
    Mobile, AL
    After reading all the battery posts...I decided to check the 12 volt charge on our newly acquired 06 Prius. After sitting overnight and with everything off I had 11.9 volts. Turning on the lights and a/c blower brought it down into the 10 volt range within 7-10 seconds. I'm new to this Prius thing...but not new to mechanics. So I figure the battery is toast! If it were in a conventional car...it probably wouldn't start the engine.
    Based on recommendation of the Forum, I ordered the Optima kit from eLearnAid.com. Although I'm sure I could have found a cheaper...lesser expensive...way to go, I believe that time is money and there is a measure of satisfaction in the non-economy method! ...not that there's anything wrong with that! :) I will report back on the delivery and installation.
    Thanks to the group for such great information...appreciated!:)
  5. wildbottom
    wildbottom New Member
    99
    What's your display reading on the Prius? How's you MPG?
    I'm looking into using a U1 Wheelchair Battery(12V 35Ah), AGM. Thanks.
    BTW, there is a Sealed version of the your battery. It also has 330 CA.
  6. wildbottom
    99
    BTW, if anyone interested in Economy Method and want the safer approach, you can buy Batteries Plus SLIU1HP lawnmower battery for $37. It's a Sealed Flooded battery with Vent. (Might need special tube or straw).Link
    If you're afraid of spillage, you can put it in a Marine Battery Box($13).
    Only problem with Lawnmower batteries is that they don't last as long. 2 years in general, maybe 3 if they are well maintained.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    My mum has a rechargable electric lawn mower, the battery generally lasts about 5 years. Of course the battery in that is too big for a Prius.
  8. vmg123
    vmg123 New Member
    How's the economy battery replacement holding up.
    need to replace mine. (2005)
    Please advise.
    Thanks,
    Vincent
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    How many miles and which state do you live? The warranty may cover it.
  10. vmg123
    vmg123 New Member
    80,000 miles in Florida.
