Battery shows wrong indication
Discussion in 'Prius c Main Forum' started by KiwiPom, Mar 11, 2017.
  1. KiwiPom
    KiwiPom New Member
    New Zealand
    2015 Prius c
    I can leave my Prius-C overnight with an almost full bar level. Next morning i drive maybe 500 meters and its showing 3 bars.
    I have even waited in carpark with radio on and after about 15mins its switched off due to power warning. This shoul dnot be case but I have mentioned it 2 or 3 times to dealer and they say its correct. I still think I have a faulty battery. Any Ideas?
  2. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    When you first start the car the engine comes on to warm up - but while it's warming up the car tries to run off the battery in order to avoid stress on the cold engine. When it does this is prefers the battery over the engine, and if you accelerate strongly it will actually draw more battery power than it normally does when the engine is warm. So if those first 500 meters include strong acceleration or an uphill climb then what you're seeing may be perfectly normal.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    I think that response is right.
    It might not hurt to check the 12 V battery though.
    If IT is weak, that would put extra drain on the HV system trying to charge it up after sitting all night.
  4. KiwiPom
    KiwiPom New Member
    New Zealand
    2015 Prius c
    Thanks for that info.
  5. bisco
    49,506
    are you waiting in the carpark with the car in 'ready', or aux? there is an auto shutdown if not in ready.
