Battery smell solved!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hobbit, Jun 3, 2010.
  1. Dovydas
    Dovydas New Member
    16
    DROGHEDA
    Do you think that would help? By the way what is the diameter of that pipe?
  2. Mendel Leisk
    42,343
    Measure the existing when you disassemble.
  3. Dovydas
    Dovydas New Member
    16
    DROGHEDA
    I have no other car to reach the shop after so need to find out the measurements before.
    Have you did that for your's prius?
  4. Mendel Leisk
    42,343
    No, sorry. Enlist a friend to drive you, or take transit or cab? Or maybe you can open it up enough to get a measurement, then button up to drive?
    There may actually be a thread here with specifics, I believe someone outlined step-by-step a while back.
    Drogheda established 1412 AD?
    #24 Mendel Leisk, Jun 15, 2017
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Considering how many GEN 3 HV batteries I've disassembled, and not one of them has the rubber vent tubes installed, why not just remove them? The gen 3 modules still have the attachment points, but NO rubber tubes.
    m.wynn and Mendel Leisk like this.
  6. Mendel Leisk
    42,343
    Raytheeagle likes this.
  7. Dovydas
    Dovydas New Member
    16
    DROGHEDA
    Do you think its a good idea just to remove them?
  8. Dovydas
    Dovydas New Member
    16
    DROGHEDA
    Thank you I'll.
  9. Mendel Leisk
    42,343
    Yeah check the link above, lots of info.
  10. Dovydas
    Dovydas New Member
    16
    DROGHEDA
    Very useful , I love you man!! :)
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Personally, if they smelled that bad, I'd just leave them removed. As I said, I've not yet seen a Gen 3 battery that has them installed. Considering the original poster stated (in his link) that he purposely uses his fingers to test for live 120vac, 240vac, etc circuits, and was happy to jam his fingers across 90vdc worth of battery modules to prove his point, I'm surprised he didn't use that as his solution.
    And...for anyone that read that link in the first post, please don't follow his examples. He appears very knowledgeable. If he is truly a professional, it was extremely irresponsible of him and shows a real disregard for safety. If he's an amateur, it shows being knowledgeable doesn't make you smart. Anyone doing that on any jobsites I've been involved with would be quickly unemployed. Whether you're a professional or amateur, careless habits such as he described lead to injuries and fatalities. I've seen people take horrific shocks. I've also seen fingers practically blown off by 480vac circuits. Do not use your fingers (or any other body part) to test for live voltage. Do you stick your hand in a radiator fan to see if its turning? If common sense doesn't apply, Darwin eventually wins.
    If you really want to replace the vent tubes, I'm sure ebay has dozens available.
    JC91006 likes this.
  12. Dovydas
    Dovydas New Member
    16
    DROGHEDA
    Well written.
    I think the pipe should be 10x14mm instead of 14x10mm or I'm wrong? Because I can't find many of 14x10
  13. Mendel Leisk
    42,343
    From various mentions in that post, sounds like the Inside Diameter of the tubing is 6 mm or 1/4". He mentions 6 mm end caps, and using a 1/4" wooden dowel as backer, when drilling holes in the tubing at vent locations.
  14. Dovydas
    Dovydas New Member
    16
    DROGHEDA
    10x14mm means 10 inside diameter and 14 means oustide diameter. 6mm is the battery tubing :D
  15. Mendel Leisk
    42,343
    I would measure, figure out some alternative transportation, be certain what you're dealing with.
  16. Dovydas
    Dovydas New Member
    16
    DROGHEDA
    For measurements I need to disassemble everything so that not the best choice when it's only transport I have :)
  17. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    OK. The tube isn't really a tube. It's more shaped like a D with the flat side having the holes for vents. The overall height is about 17.3 mm. (from the flat side to top of arch) The width is about 15.2mm. The holes are 6.9mm with about a 41mm center to center. The opening where it connects to the hard plastic tube is ~12.5mm. Overall length is ~565mm on one and about 545mm on the other.
  18. Mendel Leisk
    42,343
    I would locate the holes by as direct a method as possible. Say do the two end holes first, push the tube onto those vents, then mark all the intermediate holes using vents to locate.
  19. Dovydas
    Dovydas New Member
    16
    DROGHEDA
    You are the man! :)
  20. Allan GIbson
    Allan GIbson New Member
    Washington D.C.
    Timur did you ever find out where to purchase the replacement tubes? I have the same exact issue that you experienced.
