Battery temperature
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 4est, Jun 24, 2019.
  1. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    I went with our plugin 2013 to Greece for holiday
    I kept the charge for the final part.
    But the car did not enjoy the high Temps, so it did not allow me to use the battery to climb the hills. I did start a hybrid assistant monitoring and noticed the hv battery was between 42-44C
    At 44 it would cut off energy delivery to low kw
    I also noticed some groups were noticeably hotter. I will post the la old later
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    That's a little warm. :eek:
    Three things to consider if you haven't already.
    1. Don't be afraid to use the air conditioner on hot days. Gaining a couple mpg but cooking the battery isn't a fair trade.
    2. Make sure the battery air intakes are clear.
    3. Make sure the battery fans are clean. They are actually easier to access on the PiP than the one in a regular Prius.
  3. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Make sure Hybrid Assistant wasn't set to manually control the battery fans, tapping the fan icon changes the control mode.
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    good points
    A/C was on, it was like 33C outside so we would have cooked if not
    hybrid assistant was not started, I just started it when I wanted to see what's wrong
    Fan speed was on "3", I think that's the car automatic mode.
    I clicked on it, i it turned on "A" mode, and the speed went to 6.
    I think "A" means hybrid assistant automatic mode
    http://g-p-s.ro/Report_2019-06-23_14-15-29.html
