Battery tender for not driving car for 1.5 months
Discussion in 'Prime Main Forum (2017-2022)' started by syllablelight, Nov 14, 2021.
  1. Mendel Leisk
    41,463
    That means the charger is satisfied it's done all it can, run through a cycle, and the battery is "ok". Maybe. Butyit's not a tester.
    Test it with an electronic load tester, if you want to really see it's viability. They test Cold Cranking Amps (or a few similar parameters), and deliver a verdict.
  2. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Many auto parts stores will test your 12v battery for free. It may be a good idea to test if it was that low.
  3. Washingtonian
    Washingtonian Senior Member
    726
    621
    Pre-pandemic we often cruised 60 days at a time twice a year. I have been using two Deltran Battery Tender Junior automatic battery chargers for my PP and the wife's Lexus. Mine are model 021-0123 with an output of 12VDC at 750mA. They have always worked fine; just attach them to the + and - terminals, plug them in and shut the hood.
    ems2158 likes this.
  4. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Just checked...our 5 year old original battery reads 11.970 volts. The car gets driven every day and plugged in every day. The build date on the car is 10/16, so the battery was made in September or October, 2016. The voltage is about the same every time I've checked it over the years. I am watching the condition.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    How far / long does it get driven every day ?
    11.97 if read directly from the battery and not from an interface item on the screen, indicates that it is a little LESS that half charged and that is NOT good.
    Either it is not being charged properly OR it is about worn out.
    kenoarto likes this.
  6. Washingtonian
    726
    621
    PT Guy's comment made me go out in the garage and check mine. Similar car and environment; mine was built 03/2017. It reads 12.72V.
    However, it was being charged after a 20 mile trip a couple of hours ago. Not sure if that makes any difference.
  7. sam spade 2
    7,035
    2,803
    2017 Prius c
    Check it again after it has been sitting unused for 12 hours or more.
    If it loses more than a couple of tenths over 24 hours of no use, it probably is nearly worn out.
    That also applies if it loses a couple of tenths every day that it sits idle.
  8. Washingtonian
    726
    621
    Guess you are right. Just checked it and it reads 12.16V. Probably wouldn't be a bad idea to start looking for a new battery just to have on hand when I need it.
  9. Mendel Leisk
    41,463
    You'll need it soon.
  10. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    I have a CTEK MUS 4.3. Do I need a separate battery tender?
    I left my 2017 (original battery) plugged in for 11 days, and the battery wouldn't start the car upon returning home. I charged with the CTEK and it went through all 7 steps, so I assume the battery is still good. I topped off the water in the battery, but it was only a little low and no plates were exposed. I guess I should have left the car unplugged, as I read somewhere that it could drain the battery faster.
    Any thoughts here?
  11. Mendel Leisk
    41,463
    By “battery tender” you mean a charger that can be used long term? What you have is fine for that; it’s what I’m using.
  12. MikeDee
    1,580
    597
    Have you used the RECOND mode?
  13. Mendel Leisk
    41,463
    Once in a blue moon. I have an optima yellow top in there, installed September 2015, use the “snowflake” setting, slightly higher voltage IIRC, manual recommends for the “spiral-wound” style of battery (looks like a six pack).
    with our low use of the car these days I have the charger connected near constantly.
    for your battery, I’d get it tested, see where it’s CCA is. If it’s dropped lower than spec, I’d replace.
    you can get such testers for $50-70, DIY level. I’m using a Solar BA5, but there’s lots of choices. Konnwei KW208 looks interesting. Or Topdon BT100.
    #33 Mendel Leisk, Nov 30, 2021
  14. MikeDee
    1,580
    597
    Thanks. Just ordered the KW208.
  15. sam spade 2
    7,035
    2,803
    2017 Prius c
    Regardless of the make or model, a "reconditioning" mode is largely just marketing hype.
    You can't really recondition a wet cell battery by any combination of voltages applied externally.
    Once it's gone, it's gone.
  16. MikeDee
    1,580
    597
    What's the spec for the OEM battery? Wouldn't an older (but still good) battery be expected to have a lower CCA than new anyway?
    The replacement battery sold by Napa Auto Parts says 445 CCA.
  17. Mendel Leisk
    41,463
    Might be on the label. They tend to be lowish, 325 CCA?
    A brand new battery usually tests well above spec'd CCA, and I've found a battery testing at or below spec'd CCA is usually on it's way out. The new electronic testers seem to concur, give thumbs down verdict when CCA has dropped significantly.
    High spec'd CCA (Cold Cranking Amps) is not necessarily the best either. I'm fuzzy on it, but I understand higher CCA comes at expense of lower Amp Hours, and the latter is equally if not more important. The Toyota Prius OEM batteries tend to be a balance, average CCA and pretty good Amp Hours as well.
  18. MikeDee
    1,580
    597
    After using the car yesterday, I measured the battery voltage. 12.27v. What do you think or wait for the tester to arrive?
  19. Mendel Leisk
    41,463
    It'll survive till the tester comes, and it'd be nice to have a "patient" to test it on. But yeah, that doesn't sound good: any time a battery is chronically around 12.4 or lower it's days are numbered.
    On the flip side, I can recall an instance, let the grandkids out of the car, noticed about 18 hours later there was a door ajar. Didn't have a 12 volt "tester" as yet, but checked with a mulitmeter the voltage was 11.9. I put it on a CTEK 3300 charger, let it run to completion, which took about 12 hours. It did last a year or so after that, before I swapped to an Optima Yellow Top.
    The Yellow Tops are not necessarily the best though; I'm likely going with OEM Yuasa spec'd for 3rd gen, next time around.
  20. MikeDee
    1,580
    597
    I live in a warm climate with the car garaged, so my battery has a pretty easy life. Summers are hot though.
    What do I lose besides radio preset stations when I disconnect the battery?
