Battery unable to hold charge -- 2008 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by IanProc, Oct 28, 2023.
  1. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    Okay.
    So I have tried both — I tried leaving it on overnight after jumping it, and it died when I turned it off again.
    And then I also bought a 10amp battery charger and tried charging it overnight, still didn’t work. Though i’m not sure if I am supposed to end up turning on the car or not with the charger still connected — i didn’t
  2. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Get familiar with disconnecting the 12v bat, and not locking yourself out of the car/trunk. Charge the 12 v bat overnight with it disconnected. Get a cheap digital voltmeter so you can check the 12 bat before, during, and after charging it.
    Be careful trying to "start" your car too many times or you'll deplete the HV bat (which is what starts the engine) and you'll have to build a grid charger to charge the HV bat.
  3. Mendel Leisk
    42,332
    That's well over the 3.5 amp limit recommended in owner's manual. I'd recommend CTEK 5, though pricey. It's charging spec is 4.3 amp, at least close.
    Just my 2 cents: fugedabout AAA, warranties and so on. Read up about automotive 12 volts, learn how to maintain them, a lot less grief.
  4. JohnPrius3005
    423
    235
    get a foxsur charger from amazon, a lot cheaper.
  5. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    Yeah, I sorta got the 10amp one because AAA told me to. Guy showed me a picture and said “get this one. 10amp.”
  6. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    Does it not charge the battery if it’s connected?
  7. JohnPrius3005
    423
    235
    as Bill Clinton said what do you mean by "it"
  8. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    If the 12v is still inside the car. Does the charger not charge the 12v if it’s still inside the car?
  9. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    Okay, so right now the charger is showing this. Do I try starting the car with the battery charger still plugged in?
    Last time, when i tried starting the car after this and unplugging the charger from the jump points, it died again.
  10. pasadena_commut
    pasadena_commut Senior Member
    3,053
    951
    Southern California
    If the AAA guy put a voltmeter on the current 12V and it read <10V, or something so low that he declared it "dead", you should stop trying to resuscitate that corpse and move on. Get a new 12V, verify that it is reasonably charged (over 12.5V) before leaving the store, and install it. Then hopefully there is enough left in the pack to start the motor, and you can let the car sit for a while to charge the pack (and to a lesser extent, the 12V).
  11. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    Okay. Are you sure I should get a new 12v? The guy told me I shouldn’t get a new 12v, and to just charge it.
    If I were to buy a new 12v, where could I go to buy one and have them install it for me?
  12. pasadena_commut
    3,053
    951
    Southern California
    From everything you have described the most like scenario is that the car sat for a long time unused. The power draw from the car when it is off (some stuff is still live) drains the 12V over several weeks and if it discharges too far it damages the battery. This was a very common problem during the pandemic. There is nothing you can do to fix this AGM battery once that happens, the battery must be replaced. The observation that the car craps out once it is off is also consistent with a really bad 12V battery - when the inverter shuts down only the 12V is left to provide power, and if it cannot do so, the electronics in the car will go haywire.
    If you really think it isn't bad, then remove the 12V from the car, take it to a car parts store and have them test it. Since it is probably very discharged they will need to charge it for a while (at least half an hour) before they can run a definitive test. It will probably fail that test. If money is a problem find somebody at school who is into cars and have them help, they may already have the tools to do the same thing. If there is power near enough to the car it can be charged in situ. Since things are a little iffy in your case, it might be best to detach the ground lead and charge the battery at its posts, just on the off chance there is something else going on in the electrical system. Normally it is OK to charge the battery from the jump post under the hood, with the caveat that the maximum charging current should be less than 4A.
    Or...
    Just get a new battery. Call around to Toyota dealerships and see what they charge, or get the one from Walmart, which has been getting good reviews and will cost less. The auto parts stores all sell a version but they may not have one in stock. Once the new battery is in the car may just work. If not, at least you know it isn't the 12V. Be aware that the first time you try to start the car after changing the battery it may fail to do so or it might throw a code (I don't recall which). Just try it again and it should start normally. Assuming there isn't some other problem. And there might be, because all the attempts to start the motor may have drained the pack too much to start the motor.
  13. bisco
    52,837
    The only place to get a battery installed is the dealership or a mechanic
    if the car won’t start after you have charged the battery (try not to get confused between the 12 volt battery and the hybrid battery)
    And you’re not keen on buying a new one unless you absolutely have to, get a free load test at auto zone for a definitive result.
    Try to put out of your mind anything the triple a guy said
  14. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    Okay. I will get this thing jumped and take it to autozone
  15. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    Alright, so I took it to autozone. They told me the 12v battery was dead, so I should replace it.
    I’m going to schedule an appointment with Toyota of Eugene to get that thing replaced sometime this week! It just depends when I’m free though… I am quite literally busy until 8pm most days and the one day I’m not, I have a date! So we’ll see
  16. bisco
    52,837
    got to have your priorities (y)
  17. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    I know right! Gotta say though, right now, it’s the girl over the car.
  18. JohnPrius3005
    423
    235
    Sounds right to me.
    As you starting to see these are pretty complex cars. It’s easy to spend a ton of money trying to fix them. Many of us have learned to do some things ourselves and save a fair amount, but it’s a steep learning curve. Good luck to ya!!
  19. IanProc
    IanProc New Member
    24
    Eugene, Oregon
    Thank you!
    Yeah, I mean I could probably get a battery and fix ot myself and follow some youtube tutorial, but i’f rather they just put it in (also it’s only under warranty if i get it from the same place as where i last put in a battery).
    I might end up selling this prius after i get it fixed… I want a car with bluetooth anyways
  20. Mendel Leisk
    42,332
    The main issue I've found with Toyota batteries is the abysmal hold-down bracket: it's an odd, proprietary design, completely intolerant of any variation in height. Aftermarket batteries that are just 1/16" different, you need to shim under the battery, or add washers under the bracket, depending if the height is less or more. About on par with their scissor jack design...
