Battery vent in rear seat of 2014 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by John V Rosenbaum, Feb 13, 2023.
  1. John V Rosenbaum
    John V Rosenbaum Junior Member
    Wisconsin
    Hello - I have a 2014 regular Prius with 253,000 miles. This model has a vent next to the rear seat on the passenger side of the car. The vent is supposedly to ventilate the big battery. There is a plastic "grill" over the vent, and then a screen under the grill. I have noticed that the screen under the grill has lint covering about half of the screen, I have not figured out a way to remove the grill and vacuum the lint off the screen. Does anyone have a suggestion on how to get to that screen and clean it?
    49,811
    Maybe in your owners manual?
  3. CR94
    CR94 Senior Member
    2,642
    1,140
    Northwestern S.C.
    Easy if you remove adjacent trim and the bolt hidden below the grill, at the end of the seat.
  4. CatNinja
    CatNinja Member
    51
    28
    Hawaii
    Just search for 'prius clean hybrid battery fan' and a bunch of videos will pop up. NutzAboutBolts is one of the better videos. The first step to get to the fan is pulling out the vent.
    I'd recommend cleaning the fan when you get the time. If your vent is clogged, your fan is probably clogged too. But just initially cleaning the vent should take you about 5 min, once you figure out how to get to the bolt at the end of the seat. Either pop the seat out, our use a long extension.
  5. StarCaller
    StarCaller Senior Member
    1,250
    699
    Cedar Crest, NM, USA
    just pry it carefully off with a screw driver or something like it /
