Battery warning
Discussion in 'Gen 3 Prius Main Forum' started by PriusKyle, Jun 30, 2026.
  1. PriusKyle
    PriusKyle Junior Member
    82
    16
    Virginia
    Guys,
    Every once in a while, when I go through a carwash, I get that warning about shifting to park.
    I can’t shift to park while I’m in the tunnel as it rolls the vehicle in neutral.
    Anyone know how long you actually have before point of no return? Has anyone gone to that point of no return and what were the consequences?
    HV Battery need replacing?
    Thanks.
  2. PriusCamper
    PriusCamper Senior Member
    13,416
    5,416
    Pacific Northwest, USA
    Best solution is to only go into a car wash with a fully charged hyrbid battery. You can force charge your hybrid battery by putting it in drive and with your foot on the brake and emergency brake on you need to floor the gas pedal and the engine will charge the hybrid battery.
    Brian1954 likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,665
    1,066
    South Central PA, USA
    Not using the AC while going through the car wash will help.
    CR94 likes this.
  4. ASRDogman
    ASRDogman Senior Member
    8,051
    4,082
    Stop going through the car wash, that will resolve that issue. :LOL::ROFLMAO:
    You can always put it is drive, that way the engine will start and charge the battery.
    Or just make sure you have enough bars before going into the car wash.
    The hybrid doesn't charge in neutral. And if you're getting that warning just by sitting
    at the car wash, you may behaving hybrid battery issues. You should easily be able to
    sit at idle, with the a/c on, and radio, for 10-15 minutes.
  5. PriusKyle
    82
    16
    Virginia
    unfortunately when I do go to the car wash fully charged, I get caught in a line starts to deplete the battery and by the time I have to put it in neutral in the tunnel, I’m close to getting that placing in park warning.
  6. PriusCamper
    13,416
    5,416
    You can turn your car off entirely while waiting in line until you replace or recondition your hybrid car battery. As explained by other posters your hybrid battery has lost capacity, which can be restored via deep cycling.
  7. ASRDogman
    8,051
    4,082
    Okay, makes sense.
    Put the car in DRIVE, PRESS the brake pedal, and depress the throttle pedal.
    That will get the generators to charge the battery.
    PriusCamper likes this.
  8. PriusCamper
    13,416
    5,416
    Pretty sure they eliminated this option in 2016 and newer models, but not sure.
