Battery with AAA jump still won’t start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jbean, Dec 26, 2018.
  1. jbean
    jbean Junior Member
    78
    I Have AAA here right now and the car turns on but as soon as the cable is taken off, it goes dead.
  2. jbean
    jbean Junior Member
    78
    52,822
    your battery must be toast
    52,822
    does the engine start?
  5. jbean
    jbean Junior Member
    78
    Yea
  6. jbean
    jbean Junior Member
    78
  7. jbean
    jbean Junior Member
    78
    Can we do any other troubleshooting?
  8. bisco
    52,822
    run the engine through the warm up cycle before disconnecting the cables
  9. bisco
    52,822
    any trouble lights on the dash?
  10. Patrick Wong
    18,210
    6,517
    The 12V battery is totally dead.
    If the tow truck driver is still there now, have the driver disconnect the 12V battery negative cable at the battery.
    Apply the jump cables to the positive cable and body ground, then see if the Prius will become READY and can be driven.
    If it can, then arrange for another tow truck to come tomorrow morning and repeat that process. Immediately drive the car to the local Toyota dealer or wherever you plan to purchase a replacement 12V battery. Obviously, once you make the car IG-OFF, it will remain that way until the car is jumped again or until a new 12V battery is installed.
    #10 Patrick Wong, Dec 26, 2018
  11. jbean
    jbean Junior Member
    78
    The tow truck driver left before I read your suggestions. I’m planning to have it towed to the dealer in the morning.
    Raytheeagle likes this.
  12. JC91006
    16,936
    8,647
    You don't really have to tow to a dealer, just buy a new battery and install it. Make sure all your connections are tight.
    A dealer will do all that and charge you $350
    M in KC likes this.
