Battery Wore Down in Funeral Procession
Discussion in 'Gen 2 Prius Main Forum' started by PriusSport, May 5, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Excess charge gets used to spin the engine. In B mode it starts this right away. Without B mode the controller waits until the SOC is at a hight level, and then starts spinning the ICE to waste energy. This is analogous to dynamic braking on a locomotive, where regenerated energy is sent to a big eclectic heater on the top of the locomotive.
    If more braking is needed than you can do dynamically, friction brakes come on line.
    Tom
  2. timberwolf
    timberwolf New Member
    220
    31
    UK
    Thanks, I was beginning to wonder if I had missed something.
    As the inverter is electronically disconnected, where does any power generated go? Would it just heat up the coils in the MG motors or does the electronic disconnection still leak a little current?
  3. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    It still leaks a bit of current. It's impossible to build semiconductors that don't (just ask Intel!) As current is flowing, bits of the inverter and MGs will heat a bit, but they're cooled by the inverter coolant loop, whose pump is constantly running and pushing coolant past the power electronics, down through the transaxle, and out to the bottom third of the radiator, then back to the reservoir.
