Battery worries
Discussion in 'Gen 2 Prius Main Forum' started by sweigart89, Oct 9, 2016.
  1. sweigart89
    sweigart89 New Member
    US
    I just got a 2013 prius 2 last thrusday! I love the car. My only worry is the battery. It will go down to a 2 bar charge and up to 1 away from the top and back down again. All within 30 to 45 minites of driving. Is this normal? The gas millage is amazing. And the car is super silent! Please let me know!
  2. Mendel Leisk
    42,364
    Within 30~45 minutes, I would not worry, maybe: ours will quickly get down to 2 bars, if there's protracted low speed driving, conditions that put on a moderate load but don't kick in the engine. When conditions change, higher speeds, the charge gets back to normal levels. Another time I used to see ours go down to 2 bars, without fail: driving up through the levels of a parking garage, it was a perfect scenario for low speed and heavy load.
    That said, if the fluctuations are frequent and in normal driving conditions (not as described above), then maybe there's a problem. To allay your fears, I believe the dealership service departments can do what's called a hybrid health check, hook up to the On Board Diagnostic and check the battery health, for around $100. Or just could continue to drive and monitor; the warranty should still have a long ways to go?
    52,878
    congrats and welcome! agreed, snafu. no worries, take it on a good long drive on back roads, then try the same on the highway, you're probably fine. we're not hearing any 2013 battery issues, unless you've got 150k+ on her. the battery gauge can and will go anywhere from 2 purple to all green, and everywhere in between. all the best!(y)
  4. sweigart89
    US
    Thank you! Its only got 32k on it. And i will keep an eye on it. I think the warrenty is 100k miles or 5 years. So i have 2 years left on it. Car is so much better than the 2005 grand am i traded to get this one lol
  5. Mendel Leisk
    42,364
    Warranty depends on your state?
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Well you gotta tell us your state but its 100k miles and 8 years minimum.
    Gen3 we have heard very few batt issues and any rare reports are from 2010's
  7. sweigart89
    US
  8. bisco
    52,878
  9. sweigart89
    US
  10. eman08
    eman08 Active Member
    360
    192
    US
    Normal. You are just using the battery as you drive as it discharges and charges. I get 7 green bars when I go down hills sometimes or when I already have 6 bars from a cold start It will go green with in the first few minutes of driving and braking and then back down to purple. Purple around 3-6 bars is normal use but can drop to two bars pink if the battery was fully discharged and the ICE kicks on to charge the battery. These HV battery packs were meant to discharge 40%-80% rather than 0%-100%. Usually if you have a degrading battery, you will notice the bars going up and down rapidly charging fast and discharging fast or battery draining idling not holding a charge.
  11. Earth Day Driver
    Earth Day Driver New Member
    Seattle. WA
    We just got a 2005 Prius with 136,000 miles... was wondering if we need to anticipate replacing battery soon, and what kind of early signs to look for? Thanks :)
