BCM recall - HYBRID BATTERY FAIL
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JacobP_2021, May 13, 2021.
  1. JacobP_2021
    JacobP_2021 New Member
    Las Vegas
    My hybrid battery has given me the P0A80 error code just one year after I replaced it. I found out that my control module has a recall on it. I wonder whether my battery last year failed for the same reason.
    Do you know if Prius would help replace the battery due to the recall on the BCM? Also, I wonder how long I can drive my car without having to replace the battery (can't really afford a new one right now). Thank you all for your input.
  2. JC91006
    16,477
    8,394
    P0A80 - makes me think you didn't replace your failed battery with a new one. If you replaced it with a refurbished battery, then the battery can definitely fail again in 1 year
    Raytheeagle and Grit like this.
    49,397
    what bcm recall?(n)
    Grit likes this.
