Beefing up arm rest and
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Caco830, Jun 23, 2018.
  1. ASRDogman
    ASRDogman Senior Member
    7,833
    3,990
    I was looking into finding some of that gel. Maybe a piece people use for placing their wrists on for the keyboard.
    Which is not good because if you have things at the correct height, you won't have a problem... that's another story though. :)
    It's inexpensive, and should adjust to the elbow easily.
    52,401
    once a day, i sit in the edge of the bed and bend my head down an to the left as far as i can go. i do this 3 times for 30 seconds each. the third time, i use my hand to pull my head down. then i great on the right side.
    next, i tip my head to the left and right as far as i can, 3x30 seconds each.
    then i turn my head to the left and right, as far as possible, 3x30 seconds each.
    then i do full rotations 5 x each way.
    then i lay on my back and do 10 chin tucks with my head on a pillow, stretching the back of my neck.
    then i stand with my back to the wall, and use a tennis ball to massage between my shoulder blades.
    jerrymildred and Raytheeagle like this.
  3. Caco830
    Caco830 Junior Member
    South NJ
    Premium w/ Solar Cells
    They would have to custom make it but I can offer my armrest as a template. It will add 1-1/8” to the arm rest thickness. Is anyone interested in this? I’ve already contacted them.
    http://www.redlinegoods.com/Padding.php
    iPhone ?
  4. ASRDogman
    7,833
    3,990
    They don't list the Prius. I could buy some foam and fabric and sew the foam inside. :)
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    I run 80 miles a month. Strengthens back, neck, legs and everything that has a forward and back repetition motion.
  6. Caco830
    South NJ
    I know the dont lost the Prius. I contacted them and they said I could send in my armrest as a template. It's pretty difficult to add foam support and re wrap in leather nice and tight for a clean look.
  7. ASRDogman
    7,833
    3,990
    mmm Perhaps I misread or missaw something. :) I guess they replace the original one with theirs?
    Mine are cloth. Leather is TOO hot!
