Beep after letting up on brake
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jcoasternut, Oct 22, 2014.
  1. jcoasternut
    jcoasternut Junior Member
    Indiana
    Last week my 2008 Prius started making a faint beep each time I let up on the brake after a stop when I remove my foot off the brake. It also will make this faint beep when I let up on the brake even if the engine is not on. It is faint, nothing as loud as the beeps for seat belts or backup. The Prius is not experiecing any warning lights or any other noticeable problem and is running great. Any ideas?
    Thanks!
    John
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    It is probably a faint squeak and not an actual "beep".
    On your next maintenance visit, a shot of spray lube should take care of it.
    Data Daedalus and koolingit like this.
  3. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Oh! So that's w hat that faint beep noise really is? I would have never guessed! Mind you, I thought nothing of it really.........thought it was just the myriad Prius microprocessors cordially agreeing with each other :)
    52,596
    check your cabin filter for mice.
    GrumpyCabbie likes this.
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    air in the brake system will give a weird squeak usually when its cold. I had to get the '05 brake fluid flushed to make it stop.
  6. Data Daedalus
    1,025
    1,185
    Wembley, London
    Hahahaha.....why would mice squeak just the once, each time I braked? BTW, This is no longer happening - the noise went away after I had new front brake discs installed by Toyota last December :)
    Britprius likes this.
  7. bisco
    52,596
    that's it! mouse warning for new discs needed.(y)
