Beep-Beep-Beep
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JohnH0615, Jan 8, 2014.
  1. JohnH0615
    JohnH0615 Junior Member
    Brunswick, Ohio
    I'm having a very strange problem with my 2011 Prius.
    About two and a half hours ago, I drove home and parked my Prius for the night. About an hour after I parked, my Prius started beeping, three short beeps, every couple of munutes. It's now been doing this for over 90 minutes. Because I can hear it from the house, it is very, very, very annoying.
    I have checked all of the doors, and also took the car out for a quick spin around the block, in hopes of getting the beeping to stop. No luck. It keeps beep-beep-beeping every few minutes.
    It has been unusually cold here the past couple of days, in case that has anything to do with it. That being said, it was a good 10-15 degrees colder yesterday, yet the car wasn't having this problem. It only started this evening.
    My question is, what in the world could be causing this beeping? Is there any way to stop it?
    Thanks.
  2. peterjmc
    917
    188
    Clarksburg, MD
    Is it the horn beeping or the car lock/unlock tone?
  3. JohnH0615
    Brunswick, Ohio
    The lock/unlock tone.
  4. xliderider
    xliderider Senior Member
    7,854
    3,103
    Honolulu, HI
    Is it possible you have left a fob in the passenger compartment? Does the car let you lock the doors with your key fob?
    If you have dropped a fob between the seats, the car will beep at you and won't let you lock the doors.
    SCH-I535
  5. peterjmc
    917
    188
    Clarksburg, MD
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    The simplest answer is that somehow your vehicle was left on. Because that is the behavior it will exhibit if it is left on and you walk away.
    But I'm assuming you know how to turn off your vehicle, and also know when it is turned off.
    I would probably make sure it's off....then lock it, and put the fob far away from the vehicle.
    If the beeping returns....you have a mysterious problem.
  7. JohnH0615
    Brunswick, Ohio
    Thanks for the replies, everybody.
    I did have both of my fobs with me/not in the car, just to be sure.
    I think it may be because of low batteries in both key fobs. About a week ago, I got a message that the battery was low in the key fob that I normally use. So I did what any other person in my position and with my level of laziness would do: I put away that fob and started using the other fob instead. (Never put off until tomorrow what you can put off until next week.) That fob is now not working (I had to use the manual key to get into/start the car this morning).
    So I am going to replace the batteries in both fobs (which needs to be done regardless) and see if the original issue (with the beeping) goes away. I'm still not sure why a low battery in the key fob would = the car beeping, but it's the best idea I have right now.
    Thanks again for all of the quick/helpful replies -- I appreciate it.
  8. Den49
    Den49 Member
    498
    267
    Maryland
    Could the beeping be caused by the cold weather freezing something inside the door lock? If so, the problem may disappear when the temperature warms. You could also carefully apply heat to the door handle area with a light bulb, hair dryer or heat gun.
  9. The Electric Me
    9,083
    5,798
    Hmm...
    Well full disclosure helps.
    I hope somehow you are right and it is simply related to low batteries in one or both of your fobs.
    But it doesn't make sense in relationship to the original symptoms you are describing. If the vehicle is off, locked and your fob is kept a distance away from the vehicle. (When I'm at home I keep the fob a good distance from the vehicle) then low batteries or not, I don't think it should cause your vehicle to beep over and over.
    Infact, I think if the Prius is off, and locked, you could take your fobs- destroy them, and the vehicle would just remain off and silent.
  10. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Thanks for the link, Electric Me.
    John, same thing has been happening to our 2010 Prius.
    New batteries arriving soon - will keep you updated; you do the same! =)
  11. JohnH0615
    Brunswick, Ohio
    Update: Looks like it was a one-time-only occurrence. I replaced the battery in both of the key fobs, and winter has returned to being merely cold, instead of the bitter cold that it was last week. I'm still inclined to think it had to do with the extreme cold, and that the key fob battery replacement was a mere coincidence ... but the main thing is that it hasn't come back. Strange.
    Thanks to everybody for the replies...
  12. PardonMyPrius
    PardonMyPrius New Member
    2014 Prius v wagon
  13. PardonMyPrius
    2014 Prius v wagon
    Same beep-beep-beep every 3 seconds. Started after I had batteries replaced on both key fobs. Batteries Plus had not idea why. It was time for 12v battery replacement anyway, so we did that. My mechanic installed Toyota battery. Still beeps. It's is abnormal and has to stop. Changing 12v battery did not solve the problem. Is this a matter of reprogramming maybe?
