Beep sound for B Mode?
Discussion in 'Gen 3 Prius Technical Discussion' started by PriusOnTheFence, Nov 21, 2019.
Tags:
  1. PriusOnTheFence
    75
    29
    MA
    Is there a way to set an alarm for when you are using B mode? I often use it when I am slowing down (it also helps spare the breaks a bit), but then I sometimes forget to shift to D and find myself accelerating in B mode, which does not make sense. I quickly fix it, but sometimes not that quick.
    I asked them to disable to beep sound for when you are in reverse (the point would be for outsiders to hear it, not the driver)--might there be an option that allows you to turn this off and on for other gears as well?
    Any ideas appreciated! Please no lectures on B mode. My brakes lasted 75,000 miles so clearly the theory is not airtight. There is no problem using it when going downhill or braking.
    I would appreciate responses from people who have actually tinkered with the software and have worked with the settings that enable/disable beeping when in reverse. Not just guesses. Thanks!
    #1 PriusOnTheFence, Nov 21, 2019
  2. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    Do not use B mode for routine driving (ie, level roads, normal stop and go). There is NO need to use B mode for 'sparing the brakes'. It is used for regenerative braking on long down grades. The actual disc brakes are only (only) applied on your Prius when you are at 7 mph or below or when applying brakes HARD for an emergency stop, thus, Prius brakes (discs and pads) routinely last for 100,000 miles or more. Under normal stop and go conditions, when you apply the brake pedal, regenerative braking comes into play, and the disc brakes are not even applied. Have you read your owner's manual? Highly recommended...
    Fifen, jerrymildred and Maarten28 like this.
    49,397
    no, there is no beep, or (known) way to make it beep. agree with ed^^^ no need for b mode to slow down, just use the brakes early and gently.
    i try to anticipate stops by letting off the gas (regen) and using the brakes as little as possible (more regen)
  4. PriusOnTheFence
    75
    29
    MA
    My brakes lasted 75,000 miles, so clearly the theory does not always work. And yes, I've read the manual. And of course I don't use it on level roads--that's the whole point of the question. Please, no lectures! If you've tinkered with the software that sets the beeps, by all means. My question is very specific. Thanks.
  5. PriusCamper
    PriusCamper Senior Member
    11,067
    4,506
    Pacific Northwest, USA
    I experimented with B mode when I first got my Prius. But the more I learned about how the car worked, the less I had a good reason to use it...
  6. bisco
    49,397
    its only for long steep downhill grades
    herqulees, Mendel Leisk and Maarten28 like this.
  7. PriusOnTheFence
    75
    29
    MA
    And just a refresher of what the Manual actually DOES say:
    "Use engine braking (“B”) to maintain a safe speed when driving down a steep hill. 
    Using the brakes continuously may cause the brakes to overheat and lose effectiveness. (P. 173)"
    "To use the engine braking, shift the shift lever to “B” position.
    ●During high speed driving, you may feel that deceleration by engine brak- ing is less than that of a typical vehicle.
    ●Do not continue normal driving with the transmission in “B” for a long time.
    This may cause decreased fuel economy. To prevent this, use “D” for normal driving." (P174)
    "If the shift lever is in “N”, the hybrid battery (traction battery) will not be charged. When driving in heavy traffic, operate the vehicle with the shift lever in “D” or “B” to avoid discharging the battery." (p30)
    If Toyota did not think the B mode actually had a function, it would not include it.
    I just want to know about the warning buzzer, if it could be applied to that. It would be a good idea if it could!
  8. fuzzy1
    10,165
    It is there by federal law, useful or not. A 'downshift' gear is required, this is the closest a Prius could do.
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I do not have a literal beep for B mode, but you can't engage cruise control in B mode.
    For some one who spends 95% of the time with CC engaged, it is a tip off.
  10. PriusOnTheFence
    75
    29
    MA
    If that were the reason, the manual would not say this: ""If the shift lever is in “N”, the hybrid battery (traction battery) will not be charged. When driving in heavy traffic, operate the vehicle with the shift lever in “D” or “B” to avoid discharging the battery." (p30)"
    I am not sure why people have such a beef with B mode, but in any case, this is not the question here.
  11. fuzzy1
    10,165
    That doesn't logically follow at all.
    Long downhills are the intended use. But even in flatland markets where it is totally useless, federal law still requires it to be present.
    But only 75k on factory Prius brakes? Something is amiss here, many PC members get double that. Absent winter road salt corrosion problems, both the spouse and I got 100k on the original brakes of our traditional non-hybrids.
    While it makes no sense when accelerating, it also hurts nothing, not even fuel efficiency. Not a problem.
    The only downsides of unnecessary B use are loss of efficiency (lost energy harvest) on downgrades shorter than when it is needed, and loss of ICE auto-stop (unnecessary engine idling). When accelerating, or when running steady speeds where the ICE must be on, it does nothing more than lock out cruise control. No harm, not foul.
  12. PriusOnTheFence
    75
    29
    MA
  13. PriusOnTheFence
    75
    29
    MA
  14. PriusOnTheFence
    75
    29
    MA
    But if you could tell me what the code is so that I can insert responses within someone's quote, that would be very helpful!
  15. Leadfoot J. McCoalroller
    7,138
    6,684
    Pennsylvania
    2018 Prius c
    That's a bit of manual editing. The best way I found is to quote the original, then insert a quote-close BBcode tag at the point where you wish to "interrupt" for an inline reply.
    Then open a new, unattributed quote and paste the remainder of the original post between that and a final quote-close tag.
    Example:
    Code:
    [QUOTE="PriusOnTheFence, post: 2970199, member: 56983"]But if you could tell me what the code is[/QUOTE]
    :whistle: Little bunny foo-foo :whistle:
    [quote]so that I can insert responses within someone's quote, that would be very helpful![/QUOTE]
    renders as:
    bisco and PriusOnTheFence like this.
  16. PriusOnTheFence
    75
    29
    MA
    Dear Mr Leadfoot (we share the predicament btw!),
    Thanks so much. I had done this, but my mistake was including the full header from the first quote on all subsequent interjections and you are showing it only needs the code:
  17. PriusOnTheFence
    75
    29
    MA
    Ha, silly me, I entered the code for quote and of course it entered the quote.
    The response was:
    Thanks so much. I had done this, but my mistake was including the full header from the first quote on all subsequent interjections and you are showing it only needs the code with only the word quote. Nice and simple.
    And nice tip on emoticons. Little bunny foo-foo should be whistled at!
  18. Mendel Leisk
    38,653
    Maybe highway vs city driving? Our driving is mostly local; and extrapolating from previous checks, the latest I'd expect to be changing is around 100K miles. This is extrapolating from my previous inspection, at 66K kms, where I found pad depth around 7 mm (3.0 mm's of wear).
    Also considering minimum usable pad depth of 2mm, not Toyota spec 1mm. Really: if I opened them up and measured even 3 mm, I'd be inclined to replace anyway.
    The two bottom values are useful too I think. Again, our usage is mostly urban, not a lot of easy rolling highway driving.
    Addendum: I had in my head that new front pad thickness was 10.5 mm. It is in fact 10.0 mm. Screen grab from spreadsheet reposted, and minor edit to the text, to suit.
    #18 Mendel Leisk, Nov 22, 2019
  19. bisco
    49,397
    see post #3
    no beef with b mode, more power to you
    Grit likes this.
  20. fuzzy1
    10,165
    You very much misunderstand B mode. It does none of that. There are no simultaneous contrary forces applied to the engine.
    (FWIW, plenty of us on this forum are engineers.)
    #20 fuzzy1, Nov 22, 2019
    herqulees and jerrymildred like this.
