Beeping after my car is turned off???
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Tony Habanero, Mar 2, 2013.
  1. Tony Habanero
    Tony Habanero Junior Member
    29
    The lights are off and the key is in my pocket. The car will beep with no message. It happens 3-5 a week. Anyone else experienced this?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    1 beep: you locked it
    3 beeps: you left it in READY
  3. Tony Habanero
    29
    No. It's not that. It's like the seatbelt chime.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You need to be more specific.
    Inside the car or outside the car? After shutting off, or after exiting? Slow continuous beeps? Fast beeps? Long beeps?
    Inside the car, it will beep (like the chime) when your key fob battery is low.
    kenoarto likes this.
  5. Tony Habanero
    29
    Inside the car after turning it off. I've only had the car 3 weeks. The fob battery is low already?
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    1 beep? 3 beeps? Come on, you have to articulate if you want accurate help...
    If it is one beep, then yes your fob battery is dead.
  7. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I know it beeps after you turn it off and like open the door or wait a few seconds. Kind of like the equivalent of leaving your key in the ignition.
  8. ticleve2
    ticleve2 Junior Member
    Sure it's not the Blue Tooth dropping the signal to your phone?
  9. ghwong
    ghwong Junior Member
    32
    Singapore
    Try to turn your car off after stopping before opening any of your doors..
    If doors is open prior to turning off after stopping, it will have beeping sound. This is what I observed on my C
  10. MotorcycleGoat
    MotorcycleGoat Junior Member
    51
    23
    Yes, opening a door before turning off the car will make it beep.
  11. KRCB
    KRCB New Member
    Yes - so I read the manual a bit. The instruction was to depress the brake, push power off, then Slowly bring your foot off the brake. That works for me,....... unless I'm in a hurry.
  12. lachrisb
    lachrisb Junior Member
    35
    Los Angeles
    That's interesting, the beeping has bugged me since I bought my car, which it may just be beeping bc I have the key fob and I am still in the car but it is really annoying.
  13. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Turn the car off before you open the door.
  14. winnertakesteve
    121
    35
    I agree with others that it is most likely the result of opening the door before shutting the car off. It caught me off guard the first few times when parallel parking and opening my door to check my distance, then trying to turn the car off with the door still ajar.
  15. Maxwellian
    Maxwellian Planetary Gearhead
    Ohio
    Is there any way to stop it from chiming if you turn the car off after opening the door? I often open the door first, to check backing in or whatever, and I find it quite annoying.
  16. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I haven't found a way to do this, yet... I'm guilty of opening the door first too.
  17. Maxwellian
    Ohio
    I don't think you need to feel guilty.
    I get it, it might be best to not open the door if the car is still on. So beep at me if I do that. But after I turn the car off, the darn beep could shut up.
    ztanos likes this.
  18. Dave Stentz
    Dave Stentz New Member
    Cincinnati, Ohio
    2018 Prius Prime
    I have a similar problem. My 2018 Prius Prime Advanced beeps externally every 20 seconds while the car is turned off, and it does not stop. Does not matter if it is plugged in or not. Put new batteries in both fobs but beeping did not stop. There are no warning indicators on the dash to explain the beeping. It also does not matter whether I open the door before or after I turn off the car.
