Beeping on reverse
Discussion in 'Prime Main Forum (2017-2022)' started by maiki, Sep 15, 2018.
  1. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    You can reduce it to just a single beep on a Prius Prime. Either yourself with a tool like Carista or at a dealer who may will do it for free. Ymmv.
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    You need the plug in thingamabob and search for a code and change the code. I'm completely clueless on how, but for me, I took it to a dealer, they plugged in the thingy and changed a code. Others in here actually have the tool and have done it on their own.
  3. ttou68
    ttou68 Active Member
    351
    211
    DR. Prius app...special function.. reverse beep disable...
  4. BiomedO1
    BiomedO1 Senior Member
    4,594
    2,410
    Left Coast
    You'll also need a Bluetooth OBD2 unit.
    I posted a step by step procedure using Dr Prius and an old Samsung S7 galaxy phone a while back; but any android peripheral should work.
    Dr. Prius & the 2021 Prime LE | PriusChat
    Good Luck
    #44 BiomedO1, Dec 10, 2022
    Montgomery likes this.
