Beeping while driving with hatchback open
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Jun 6, 2015.
  1. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I bought carpet and loaded it into the PIP, needing to strap down the hatchback with the carpet sticking out.
    As soon as I drove off both turn signals started flashing and a tone beeping.
    The flashers stopped after a minute, but the beeping sounded all the way home.
    Very Annoying.
    Good thing I wasn't going cross-country !!!
    52,889
    i'll have to try that, that's new compared to my gen II's anyway. btw, can you resort the spreadsheet by date? someone messed it up. thanks!
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  4. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    It's a Toyota thing. My 2012 PIP and a friend's Toyota SUV both do it when hauling kayaks with hatch tied. No way to shut off, AFAIK.
  5. frodoz737
    frodoz737 Top Wrench
    4,810
    2,562
    33
    If it didn't, someone would sue Toyota. :LOL:
    #5 frodoz737, Jun 6, 2015
  6. ETC(SS)
    7,575
    You wouldn't have made it across the country, and the beeping and flashing aren't nearly as annoying as a ride in an ambulance (or worse!)
    lensovet likes this.
  7. bisco
    52,889
    i wonder if prius puts out enough co to be harmful?
  8. Mendel Leisk
    42,369
    ^ That's one issue oft cited. Honda was more laissez faire: just cautioned if you're driving with hatch open to keep cabin windows down too, something like that.
    You probably suck in more CO just driving behind some joker's "collector" car. :(
  9. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    The latch (the part down in the trunk rim) has a sensor so it knows if it is in the "Open" or the "Closed" position. When you swing the hatch down it pushes a metal rod in there and closes. You can use a screwdriver or a nail or something to press it down into the "closed" position even though the hatch is open. Remember to use the rubber open button on the lid to open the latch when you are done hauling. Otherwise when you close the lid it just slams against the (still in the closed position) latch and bounces open again.
    Frontporch and valde3 like this.
