Behaviour modification?
Discussion in 'Prime Main Forum (2017-2022)' started by scm2000, Aug 23, 2017.
  1. scm2000
    scm2000 Active Member
    164
    125
    My commute was mostly expressway, 31 miles round trip.
    But I did some playing on Google Maps, and found a route that cuts a mile off the round trip, and cuts the expressway miles in roughly half.
    It will take a week to see what the travel time is like, because my commute time is so variable anyways because I don't have a set schedule.
    Anyways... the benefit seems to be better miles per kwh... 30 miles round trip with 6 miles remaining.
    36 miles on a charge is pretty good I think.
    Anyways, has anyone else modified their routes for better economy?
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Yes, I put my comments in my "Prime Driving Habits" post!
    I have recently started doing what you're describing, driving shorter surface street routes to favor my electric mode!
    scm2000 likes this.
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I did... back in 2000 with my first Prius... long before Google Maps.
    Watching the screen, it became obvious certain routes for more efficient than others.
    In those days, there was much less EV available and it was all derived from gas. So, you really watched what bumped the MPG overall.
    HPrimeAdvanced likes this.
  4. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    If a car can change our driving habits there may be hope for mankind yet.
  5. Janice N
    Janice N Member
    51
    58
    Redwood City, CA
    YES! I've been thinking about this lately. If I take surface streets I can get two round trips (commute) into one charge instead of one and a half. It adds 5 min each way. I found myself getting annoyed at plugging it in everyday at work (wait for an open spigot, move car, plug in, walk to office, wait 2 hours, walk to car, unplug, move car) and with this route, I only have to do that 3xs/week instead of 5 now.
    I realized that my old route on the freeway wasn't that much fun to drive in this car anyway. My previous car was small, over-powered, and had manual transmission. Charging up the hill then accelerating hard to get to highway speed was really fun, not so much with this car - even if I ignored the crazy fuel inefficiency, it handles like a tank (in comparison) and I never feel like I'm driving fast.
    That rush helped vent frustration. I wonder if the new car is part of my increasing job dissatisfaction?
    scm2000 and HPrimeAdvanced like this.
  6. MNdriver
    MNdriver Senior Member
    549
    577
    My commute is half city streets and half on a parkway that follows the Mississippi River. Today I weaved home on city streets on a route that involved more turns but resulted in one less Stop sign. I'm going to try that for a couple of days. I'm getting 2 days of driving on a charge but I'm on the cusp of 3. Trying to eek another mile out of it!
    HPrimeAdvanced, huskers and scm2000 like this.
  7. drysider
    drysider Active Member
    823
    337
    Liberty Lake WA
    A good portion of the EV increase you see is the additional regeneration you get on surface roads. There isn't much opportunity to regen on the freeway. It is the main reason the Prius has better city mileage than highway.
    HPrimeAdvanced and scm2000 like this.
  8. bwilson4web
    16,540
    Full disclosure, I am retired and have two plug-in hybrids: 2014 BMW i3-REx and 2017 Prius Prime. After leaving the Marines in 1975, I resigned seven times, the last for retirement:
    With two exceptions, my resignations were driven by contract or projects ending. The exceptions were one personality conflict and the other case, a change in work rules that increased hours without pay.
    How I got to and from work never played a significant part of my resignations. Rather, I've always driven calmly (to my wife's angst) or taken public transportation so I can also plan my work day. So it could be driving 'Prius-like' might have given more time to think strategic.
    GOOD LUCK!
  9. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I'm not so sure.
    I'm assuming that the regen you are talking about is not because you are going downhill.
    If you are in traffic and you speed up, then brake you are wasting energy compared to just driving at a constant speed. Yes, when you are using regen you are wasting less than in a conventional car, but you are still losing some energy.
    The reason you get better miles/kwh on side streets compared to constant speed highway driving is because you are driving slower and thus have less wind resistance. The slower you go the better until the car's baseline power usage for just being on has a bigger effect than wind resistance.
    Mike
    jerrymildred, heiwa, fuzzy1 and 4 others like this.
  10. scm2000
    164
    125
    Part of it is this too... from home to work I climb 160 feet in elevation... so it should cost less to return from work than to go to work.
    Except on my old route... The return trip is not a reverse of the trip out... its an issue of expressways not always having an entrance matching every exit. It happens that the return trip has significant up hill climbs that the trip out doesn't have.... one especially from a dead stop, and the traffic demands you make the speed limit going uphill. That costs a lot of power... and though you get regen on the downhill side it doesn't make up for the climb,
    The new route back is a reverse of the route out.. and has no significant uphills on the return trip...
    The old route was 15.5 miles each way with about 12.5 expressway driving. Half of that was stop and go, half was at road speed.
    The new route takes a few miles to get to the expressway, then only stop and go traffic on the expressway for about 6 miles, then surface streets the rest of the way.... In other words. I cut out the high speed portion and shortened the round trip 1 mile to boot.
    The only reason I take the express way home at all now is a "you can't get there from here" problem... any route that cuts it out has significant back-tracking.
    by the way.. based on the one day... there is no difference in average speed between the old route and new route... it's just how the speed is spread out that makes the difference.
  11. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I use Evtripplanner for route planning on less-traveled and longer routes. I've had times where I've found a 20% reduction in electricity used versus the "obvious" route.
  12. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    i have three possible routes: interstate, highway, non-highway.
    I rarely use the interstate and only use the highway when in a hurry. The Prius has taught me to appreciate the less-direct and not-the-fastest route.
  13. drysider
    823
    337
    Liberty Lake WA
    Wind resistance is definitely a factor in mpg, but we are discussing total EV miles, which are increased through regenerating energy into the battery, regardless of the source. In any case, in stop and go traffic you have to, well, stop and go. The regen system allows you to save a bit of the energy that is usually wasted as heat. It costs you nothing since you were going to stop anyway. If you were to stop on purpose just to charge the battery, that would be costing you gas dollars. Regenerated energy from normal surface street driving has little or no cost, with the result that the energy in the battery is almost always the cheapest available. Even when the engine is charging the battery, the Synergy Firmware uses what it determines to be excess energy. While the engine will run just to charge the battery, it only occurs when you are parked and your mileage is zero anyway.
  14. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    In other threads, I've heard of our engineer friends talking about attaining better efficiency by reducing need for breaking (driving at the speed that requires less breaking) because regen does not capture full energy expended. I tried it, and confirmed that it indeed increases my mile/kwh figures. Driving slow, like 60mph on hwy, allows me to complete my commute of 36-37 miles in full EV. I have come to enjoy stop-n-go traffic (slow) because PP exells in such condition.
    scm2000 and jerrymildred like this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    I agree with @3PriusMike. You're only looking at the regeneration side of the stop and go equation. Watch your power bar when you accelerate. It's way higher than at a steady speed because you're overcoming inertia. And that higher current is generating more heat because of resistance in the wires and windings, which is an energy loss. When you brake, you get some of that back, but not all of it because of those same heat losses. It's far far better than with a gasser because a gasser wastes all the kinetic energy as heat and brake pad dust. But it's still a net loss if you have to stop and re-accellerate. (Unless you can supercool the HV cables, battery, inverter, and motors. :D)
  16. drysider
    823
    337
    Liberty Lake WA
    I do not agree. What you are leaving out is that you HAVE to stop. You HAVE to waste kinetic energy as heat. And you HAVE to speed up afterward. Whether the energy it is reclaimed or not makes no difference to your energy COSTS. However, if you are able put a bit back into the battery, you are getting something for nothing, or, at least, very little. I spent many decades designing energy reclaim systems and the only cost associated with the reclaimed energy is the cost of the equipment and materials that go into building the system. Now, if you purposely speed up and hit the brakes JUST to recharge the battery, all bets are off. Stupid is almost always costly.
  17. Lee Jay
    5,850
    4,036
    Stop talking past each other. Remember the statement you are both answering.
    "If you are in traffic and you speed up, then brake you are wasting energy compared to just driving at a constant speed. Yes, when you are using regen you are wasting less than in a conventional car, but you are still losing some energy."
    That statement is correct from start to finish. So is this one, except for the misspelling of "braking":
    "I've heard of our engineer friends talking about attaining better efficiency by reducing need for breaking (driving at the speed that requires less breaking) because regen does not capture full energy expended."
    So, yes, regen is better than no regen if you have to stop. But driving slower so that you can coast is better than accelerating more just to regen later.
    jerrymildred and heiwa like this.
  18. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    Forgive me for misspelling "braking" as English is my second language. I appreciate engineers like you whose use of language is so precise. We can learn so much from you guys if we are open to listening.
  19. bwilson4web
    16,540
    Although harder to quantify, our Prius also takes pains to operate the engine at peak efficiency using the traction battery to bank or withdraw the gap between the load and peak efficiency. Over time, the Toyota engineers have tuned their control laws very cleverly. Understand I don't object to burning fossil fuels, just burning them stupidly.
  20. jerrymildred
    11,517
    14,170
    Tampa, FL
    Exactly. Thanks, Lee.
