Benefits of wheel spacer?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by WolfpackBill, Mar 14, 2016.
  1. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I have 15" OEM wheels and I am not planning to get bigger rims because I drive almost 100 miles a day. I've been seeing many members with new rims and need wheel spacers to bring the wheels out toward the side of the car to make the wheels less "tucked" in. I understand the cosmetics of them and the need for them for brake caliper clearance and such.
    I'm wondering what are the advantages and disadvantages of wheel spacers and would it benefit me if I have no desire to change rims but maybe add wheel spacers to increase the width of track maybe? Any handling benefits?
    Dylan Doxey likes this.
  2. andino
    andino Senior Member
    746
    550
    San Jose, CA
    Spacers are useful if you have/get wheels that aren't the proper offset for the look you're trying to achieve. As far as performance gains, you likely won't see much more than a visual gain from adding wheels spacers with the stock wheels. Unless you're trying to achieve a more flush look, then its probably not necessary. You'll see more of a difference in going with a more performance oriented tire or swapping to wider wheels.
  3. xliderider
    xliderider Senior Member
    8,056
    3,224
    Honolulu, HI
    You will be changing the geometry of the suspension relative to each other, so there will be slightly more stress on the struts, the camber might change slightly, etc.
    Unsprung mass will also be increased.
    #3 xliderider, Mar 14, 2016
    Xterra72 and Dylan Doxey like this.
