Best AGM 12V battery for Gen 4?
Discussion in 'Gen 4 Prius Main Forum' started by Scuderia Priusi, Apr 29, 2017.
  1. Scuderia Priusi
    96
    111
    PacNW
    I want to replace the stock 12V battery in my Gen 4. I've had excellent results with the Optoma Yellow-top battery I put in my wife's Matrix, but when I check the Optoma configurator online, they show 'no battery available for your vehicle". :(
    Is that true? Has anyone put an Optoma of whatever color/flavor in their Gen 4 Prius? I definitely want to go with an AGM battery, so if not Optoma, can anyone recommend another AGM battery that fits? TIA!
  2. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Why do you want to replace the 12V battery? Is it defective?
    Mendel Leisk and RCO like this.
  3. Prodigyplace
    12,713
    11,848
    Central Virginia
    Why an agm? There is no venting issue with the battery now under the hood.
    The stock battery looks like a standard lead acid design.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    AGM? Obviously not an annual general meeting.....
  5. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    OK, thanks. A bit older and a bit wiser now.
    srivenkat, bisco and Prodigyplace like this.
  7. Prodigyplace
    12,713
    11,848
    Central Virginia
    The older Prius models all used AGM batteries. The battery was located beside the cargo area and vented to the outside.
    Josem3 and RCO like this.
  8. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Why ??
    If the car is about a year old, this likely is a complete waste of money.
    And if you have some solid indication that there is something wrong with the 12 V battery your warranty should cover it.
    AGM is generally a better choice but there is no good reason to throw away a few years of remaining good health in the OEM one.
    If you insist on doing this now........any major brand AGM should be fine.
    In my opinion, the Optima ones are little or no better than the others and thus are overpriced.
    RCO and Mendel Leisk like this.
  9. bisco
    52,855
    just go with a standard lead acid car battery. they are time proven, and economical, compared to agm.
    RCO likes this.
  10. Mendel Leisk
    42,347
    And the one that's in there will serve fine. (y)
    RCO and bisco like this.
  11. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Didn't I read someone just today say that TOYOTA warranty on the original 12V battery is 7 years - if it's faulty, TOYOTA should fix it.
    RCO likes this.
  12. bisco
    52,855
    agreed. would like to hear more from o/p about replacing a perfectly good, almost new battery.
  13. Prodigyplace
    12,713
    11,848
    Central Virginia
    The 12 volt battery does not appear to be mentioned in the 2016 service and warranty guide, so I assume the 3 year warranty (36 month or 36K miles) applies.
    java007md, Josem3 and RCO like this.
  14. Mendel Leisk
    42,347
    Both the Canadian and US warranty booklets are oddly silent on the 12 volt battery, nothing in inclusions or exclusions.
    I would suspect Toyota is obligated to deliver the car to you with a functioning battery in good condition, nothing more. But it should be spelled out in that document.
    It is just too easy to run a battery down.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Let me muddy the warranty waters, it you buy a Toyota TrueStart battery at the parts counter, it has a 84 month prorated warranty. (24 month roadside assistance, 24 month 100% replacement) The same battery in your car when you purchase it, has only a 36 month warranty.
    TrueStart
    84-month service replacement warranty
    24-month of roadside assistance reimbursement
    Years 1-2 100% of parts, service and towing
    Years 3-4 50% of Truestart MSRP
    Years 5-7 25% of Truestart MSRP
    They also sell a True-2 battery which has a much lower warranty.
    #15 JimboPalmer, Apr 30, 2017
    Josem3, alanclarkeau and RCO like this.
  16. Prodigyplace
    12,713
    11,848
    Central Virginia
    It that for a Gen 4 battery? The battery technology in the 12 volt battery appears to be different in the Gen 4.
  17. Prodigyplace
    12,713
    11,848
    Central Virginia
    Oxy and RCO like this.
  18. Mendel Leisk
    42,347
    @JimboPalmer , that's kinda like muffler and brake pad at Honda, which often come with "lifetime" warranty. It's a calculated risk: replacements of this sort tend to happen about halfway through a vehicle's life, so lifetime warranty on genuine Honda replacement parts (typically with a proviso that they be dealership installed) keeps owners "in the fold", and with relatively low odds they'll be back another time for the same problem.
    RCO likes this.
  19. Prodigyplace
    12,713
    11,848
    Central Virginia
    Partially true. Toyota has two 12 volt battery lines but their online guide does not list ones for the Prius family but directs you to call them, basically,
    From https://www.toyota.com/toyota-owners-theme/pdf/03_Batteries2015_final[1].pdf
    RCO likes this.
  20. Prodigyplace
    12,713
    11,848
    Central Virginia
