Best Alternative to Toyota FJ40
Discussion in 'Fred's House of Pancakes' started by M8s, Sep 9, 2011.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    I agree 100%. I misunderstood M8s, thinking he just wanted a good trailhead accessor. I've taken the my RAV, which has the 2.4L 4 cyl 160 hp 5 spd manual and LOTS of power, to many places in the CO/NM backcountry. I know what it can and cannot do. But it is more rally car than rock crawler.
    I'd love to have a Land Cruiser of any year. My cousin restored a diesel FJ that he imported from Canada and it is stunning! But the newer ones are expensive and so I have Sequoia's instead. I think perhaps you meant Land Rover? My sister had one of those, an early 2000s Discovery, and paid either the Land Rover dealer or the Land Rover independent specialist about $2000/yr in repairs and maintenance. Imagine being told, "Yes, we can fix the leak at the rear main seal, but it will only last a year or two." She has a Pathfinder now -- cheaper than a comparable 4Runner. :( My mom had a 96 Grand Cherokee LTD, pretty nice inside, but the V6 was way underpowered, and it was on its 3rd fuel pump when the transmission went. That thing was damn squirrly on ice too -- perhaps due to the full time 4x4 -- Mom and I both lost control of it on separate occasions, and it has never happened to us in any other vehicle because we are pretty cautious winter drivers. She had a Highlander LTD now and needs it, living at 8000' in Colorado. I have never owned a Jeep but I have owned Chrysler products and every last one was a POS, the worst of the big 3.
  2. Trollbait
    12,388
    I thought the secret to handling soft sand was lowering the tire pressure.
  3. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    Don't know about cars, but on a dirt bike you need traction on the drive wheel but want the front tire just skimming the sand. Therefore, you keep a light touch on the handlebars, stick your butt out as far as you can, give it plenty of gas and steer with your footpegs. I never aired down for sand. Of course, I had gnarly knobbies that give incredible traction.
  4. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Yes, I meant to say Land Rover, and I agree they are expensive and expensive to work on. Also, I have a hard time comparing a Jeep Grand Cheokee to a Jeep Wrangler (the only real Jeep IMO). The CJ/YJ/TL Wrangler Style Jeep has not changed in years, and there's good reason. Also, the in-line 6 is the only way to go in any Jeep product, they have a strong reputation of going 300K miles or better and are extremely easy to work on. Jeep CJ/YJ/TJ models do hold up relatively well, however, I do need to caveat that with reliability having a direct correlation to use! If you're beating the crap out of it rock crawling, then yea, thinbs break, but you generally know that going in. On the plus side, parts are readily available and relatively cheap. As for any other product sold under the Chrysler brand, I'm with you, they are crap, and I wouldn't own one!
  5. Paul58
    1,126
    125
    Atlanta
    Behold the beauty of a low range transfer case... It's amazing how that and low gears really make a Jeep feel as if it could climb a telephone pole! As previoulsy mentioned, airing down the tires is key when traversing soft sand, that and not stopping in the middle of it, as you eluded to by your method of cross soft sand on your motorcycle. In a situation of 12" deep sand, ground clearance and high flotation tires will be your best bet! And don't forget the portable air pump so you can add air before getting back on the blacktop!
    I really wanted a 2005 or 2006 Wrangler when I was looking. Those years have the 6 speed manual transmission. Also, the 4 cyl in those is a dual overhead cam design that does give a little more power over the previous model 4. I'd still opt for the 6 cly if you can find one, especially if you ever plan on towing a trailer (which it sounds you might if you have motorcycles). The "X" is the base model, it's the same model I have. Depending upon the options, the only difference I've been able to find from the "Sport" is I don't have cruise control.
  6. Trollbait
    12,388
    If it is just the two of you, what about a small pick up?
    Not as glamorous as a Jeep or FJ, but having the bed on hand can be handy.
  7. amped
    amped Senior Member
    3,892
    694
    Columbia River Gorge, Oregon
    I've owned at least one of every Land Cruiser, 4Runner (except newest gen) and FJ Cruiser models ever imported into the US.
    IMO the FJ Cruiser with the full-time 6M/T drivetrain (w/RR locker standard) comes closest to your needs but has a fixed roof.
    I've driven mine stock over most of the Oregon Trail in my state, navigate trails rated 4 out of 5 through mountain passes and sail through moderate sand and snow with stock tires. It would easily handle any of the roads/trails you mention. The M/T has an~ 45:1 crawl vs. ~32:1 on the A/T's. Not the 65:1 on Rubicon, but more than adequate with the 1GR 4.0 V-6 VVT-i low-end torque.
    You can find an '07 (late production w/A-TRAC mod) for mid-teens most anywhere.
  8. M8s
    614
    113
    33
    WOW, those are some meaningful credentials!
    A friend of mine with an H1 (he has an "H3 Recovery Vehicle" sticker on it) told me that the FJ Cruiser was the real deal off-raod. I'd give a ton for a 3/4 size FJ Cruiser. I just don't want such a big car now that we live in smaller houses.
    The search continues.
    I just came back from CO Springs where we drove a Jeep Wrangler for the first time. I drove it for an hour or so. It's a '98 in pristine condition with 47.8k miles . . . and an automatic. It looked great, was reasonably comfortable on the road and handled better than I'd expected. But it was slooow (probably due to the AT). Bottom line: I learned that I'm not a Jeep guy. I was expecting something that felt like a small FJ Cruiser but was disappointed. My Prius could beat it in a drag race.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Not all Jeeps are slow. My 1972 Jeep C-J5 came from the factory with a V8. That was a very small truck for that big of an engine. It couldn't go much over 90 mph as it ran out of gears, but it was pretty quick up to that.
    In truth you don't need a lot of power off road, except under some very special circumstances. It's mostly gearing. One of my friends had a Jeep with a straight six, the other had a four. They all did fine off road.
    Tom
  10. Paul58
    1,126
    125
    Atlanta
    Ha! Yep, they certainly aren't race cars, that's for sure! Did it have the 4 or 6? The 4 is definitely lacking on the road! The AT doesn't help either, on either engine. I have the 5 speed with the 6, but my Prius would still easily blow it away. But then again, that's not what their made for, and they are good at what they are made for. The AT tends to suck gas too...
    A buddy has a 2004 Sahara with the AT and 6 cyl and I tend to leave him behind when we take off in the Jeeps (especially from a stop light). He says the best he gets on gas mileage is 14 mpg, my last tank I got 18 mpg, and that was all city driving. But then again, I tend to drive the Jeep like I drive the Prius, and I doubt he drives that conservatively.
  11. M8s
    614
    113
    33
    Yep, you guessed it. It was a '98 Sahara with a 6 cyl and a 3-speed automatic. Being a 3-speed, I'm sure the gear ratios are as wide as possible to try to suit every speed you're likely to go. If it had a 5 speed MT my opinion might have been different - except it felt cramped, too. It really was a creampuff in most ways and looked killer but it felt like, well, the junky American cars I had as a kid. (I didn't get to drive it off road but I did go over some curbs in the parking lot and it handled them like they were speed bumps.)
  12. Paul58
    1,126
    125
    Atlanta
    This is what you need, a nice new 2011 Icon FJ44! Only $150K
  13. M8s
    614
    113
    33
  14. Paul58
    1,126
    125
    Atlanta
    I'm betting they'd take $99K, that's $51K less than a new one! What a bargain! Gotta love the internet!
