1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Best Battery Charger / Conditioner ?? Help wife is gonna kill me
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SEaton, Dec 1, 2013.
  1. marcs_carhole
    marcs_carhole Junior Member
    44
    Durham, NC, USA
    Did you start with the discharge?
    What makes you think it is overcharging? Note that you will need to charge beyond the rated capacity of the battery since the efficiency is something less than 100%, e.g. if you put 7200 mAhr in you will not get 7200 out. (I am seeing around 85% efficiency, i.e. a module might be charged with 7250 mAhr but will then only discharge 6100 mAhr.) For initial attempts, I charged to 7250 mAhr. The delta-V cut the charging off on about 1/3 of the modules. For the other 2/3, it charged to the 7250 cutoff. Since delta-V was not hit, those modules could have been charged further to get to their full capacity.
    Britprius typically uses 7250 and I believe that is what's used in sideways' lengthy thread. JeffD uses a cutoff of 7500 mAhr to get closer to the full capacity.
    The module should be charged well over 7.2V. The nominal cell voltage for NiCd is 1.2V and for NiMH it's 1.25V. However, a fully-charged cell will be more in the 1.4 to 1.5V range.
    So, you might not really have a problem.
  2. SEaton
    SEaton Junior Member
    29
    Eagle Mountain, Utah
    2002 Prius
    well this morning I checked the batteries and they were still charging, but their voltages were up at like 8.6V. I thought that was too high, maybe I was wrong.
  3. marcs_carhole
    44
    Durham, NC, USA
    Saw in another thread that you stated you were having problems with your balancing. How about an update ...
  4. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    So in conclusion, you guys think it would be safe to charge at 5A and discharge at 3A or more?
Loading...
