Best brand of gasoline?
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by garen2001, Jan 22, 2024.
  1. ken2023
    ken2023 Member
    71
    55
    new jersey
    2023 Prius Prime
    XSE Premium
    The other methods of oxygenation (MTBE) produce more pollution. Ethanol is cleaner.
    mountaineer likes this.
  2. Trollbait
    12,735
    Top Tier doesn't refer to the gasoline fraction itself, but the additive package that gets added when the delivery tanker truck is being filled. The level of detergents the EPA requires is a minimum. Top Tier is a higher or more effective level that was established by a consortium of auto manufacturers.
    There are other oxygenates. MTBE was used because it was a by-product, and thus essentially free to the refinery. It hasn't been in gasoline since 2004, so any ethanol free gas sold for road is using something else.
    I'm not even sure a modern car engine needs oxygenates. Much of the EPA formulation is to address emissions from older cars, maybe even power equipment and off road uses.
  3. Gokhan
    Gokhan Senior Member
    6,613
    2,627
    Paramount CA
    Any major brand (possibly even Arco) should be good. No one knows which major brand is better or best. I am loyal to Chevron. However, I would be worried about cheap brands. There is definitely bad gas out there that could harm your fuel system and/or engine.
    There is absolutely no need for any higher than the recommended 87 octane in a Toyota (unless otherwise recommended). You will not notice any difference in any ways with a higher octane.
  4. Mr.Vanvandenburg
    1,358
    604
    2020 Prius Prime
    I have been using Costco. The lines aren’t long where I go. Top tier now, and I want alcohol to absorb water. I trust Costco as a retailer, and the volume sold means likely fresher gas.
    Having to drain an entire tank of gas once due to water back in the day, lesson learned, and happy it’s all got alcohol in it now where I live. No problems ever since the gas got alcohol, 10% I think.
  5. Gokhan
    6,613
    2,627
    Paramount CA
    Here is the list of the TOP TIERâ„¢ stations. Always go to a TOP TIERâ„¢ station.
    Fuel Stations—TOP TIER™
    In the US, they are:
    • 76
    • Aloha
    • ARCO
    • Beacon
    • Belmont Car Wash
    • Cenex
    • Chevron
    • CITGO
    • Conoco
    • Costco Wholesale
    • CountryMark
    • Dash In
    • Diamond Shamrock
    • Express Mart - Wisconsin
    • Exxon
    • Fast Fuel
    • Gold Medal Gasoline
    • Harmons Fuel Stop
    • Hele
    • HFN - Hawaii Fueling Network
    • J&E Wendy
    • Kirkland Signature Gasoline
    • Marathon
    • Mega Saver
    • Meijer
    • Meijer Express
    • Mobil
    • Ohana Fuels
    • Phillips 66
    • QT
    • QuikTrip
    • Ranger
    • Ranger Fuel
    • Ranger Mustang
    • Ranger Stallion
    • Ranger Thoroughbred
    • Reeders
    • Road Ranger
    • Rutter's
    • Shamrock
    • Shell
    • Shell Nitrogen Enriched
    • Shell V-Power
    • Shell V-Power NiTRO+
    • Simonson Station Stores
    • Sinclair
    • Sunoco
    • Texaco
    • True Turbo
    • Tulalip Market
    • Valero
    • Value America
    • Waterway Fuels
    • Win Win
    • WOW
    TGrracie and RandyPete like this.
  6. DOHCtor
    DOHCtor Active Member
    170
    102
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Last time i checked, 10% ethanol was mandatory in all fuel grades here in Canada since like 2022.. That would explain why i wasn't able to find ethanol free premium fuel nearby. Shame, the Civic used to love that ethanol free Shell V-Power..
    What are the Clean Fuel Regulations? - Canada.ca
    Thanks for nothing Justin you bastard...
    TGrracie and douglasjre like this.
  7. Mendel Leisk
    42,052
    Chevron 94 is ethanol free, at least on the west coast. FWIW, I’ve tried it, didn’t notice a difference. Maybe the straight gas advantage offset by the higher (harder to ignite) octane??
  8. novak068
    novak068 Junior Member
    US
    the difference between gasoline with ethanol and without it may be insignificant. I also dont notice a significant difference in performance, fuel economy.
    TGrracie and Mendel Leisk like this.
  9. Trollbait
    12,735
    Higher octanes tend to have less energy, though I don't think enough to match E10's level. Seasonal blends also vary in energy content. By around the same amount as E10 and E0. A winter E0 will be the same as a summer E10.
  10. ColoradoBoo
    ColoradoBoo Senior Member
    1,300
    919
    Monument, Colorado USA
    We have a new gas station that recently opened near me...Quick Trip. I was happy to see the "Top Tier" fuel sticker on their pumps and, this week, also learned that they do NOT add the ethanol into their gasoline...win/win for sure!
    kerbear54 and Gokhan like this.
  11. Gokhan
    6,613
    2,627
    Paramount CA
    Yes, they are in the list I posted above.
    ColoradoBoo likes this.
  12. Paul Gregory
    Paul Gregory Senior Member
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    When tetraethyl lead (TEL) was banned, a valve protectant and anti-knock additive, it was replaced with MTBE, which turned out to be worse in many ways. Ethanol was added as a safer substitute, but I believe technology has made it less relevant. The knocking problem has been somewhat mitigated by sensor monitoring and computer-controlled timing.
    The steel valves that TEL was added to protect, have been supplanted by stellite and other materials, not as prone to heat erosion as before. The knocking problem began to appear as engines were designed for higher compression, higher RPM and higher internal temperatures. TEL remained as the additive of choice, because of its low cost and effectiveness, until it was banned in most places.
  13. CKLE
    CKLE New Member
    2024 Prius
    I have been using Costco since my first fill up (currently at 5k miles, 24LE) and averaging 56-57 mpg. I recently put in a tank of Marathon and my mileage went up 2 mpg. Same route, same weather-pouring rain actually-and today, on the second tank of Marathon I averaged 60 on the work commute (74 mph 50 miles freeway over flat terrain). Could be an outlier but I'm going to stick with Marathon for a few more thanks to see if it holds. I'll post an update on a few weeks.
    TGrracie and kerbear54 like this.
  14. Paul Gregory
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    I can't say for sure, but I think I read somewhere that all gasolines must measure up to the same standards.
  15. bionicbadger
    bionicbadger Junior Member
    Alberta
    You can google for ethanol free gas, or go to the pure-gas org website and find stations near you that have ethanol free. Though it doesn't show any in Quebec
  16. Preebee
    Preebee Senior Member
    870
    771
    Midwest
    2023 Prius
    Get the cheapest gas you can find from a station that has good traffic. And don't fill up when a tanker is delivering gas.
    Also, don't top off your tank. Stop at the first click. And refuel at the slowest rate possible (first notch on handle).
  17. Bill Norton
    Bill Norton Senior Member
    2,220
    746
    MONW, Ks.
    2019 Prius
    L Eco
    I'm searching for "The Best Electricity".
    Preebee likes this.
  18. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Best gas is Top Tier. Probably a little more in cost but worth it for piece of mind IMO.
    kerbear54 likes this.
  19. kerbear54
    kerbear54 Junior Member
    I am so jealous! We just have e10 at nearly all stations. Can't remember filling up without it.
  20. Bill Norton
    2,220
    746
    MONW, Ks.
    2019 Prius
    L Eco
    They all taste the same. (y)
    Why does there always have to be a 'Best of ...'?
    It's hard to measure the difference with No Alcohol. The cost difference doesn't work out.
