Best car wash equipment?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by macmaster05, Jan 15, 2011.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I don't think it's best to 'wash' the car (with soap) using a cloth or towel. Use the tools that the pros designed.
    Read my warning post above how you can do the most damage marring finish during washing.
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Those are good tips also.
    How long should I expect a genuine sheepskin wash mitt to last?
    I've always paid someone to handwash my cars, but in the interest of saving money I will try to do more of it myself. I'm not going to get into claying just yet. I want to get into the routine of washing. Then I will start waxing after the next couple washes. Hopefully the factory/dealer wax holds up for a little longer.
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Don't mean to be arrogant, but I think I've become pretty good at car drying ....
    * Get most of the water up in a section with a good car drying towel - waffle weave microfiber, synthetic chamois, whatever... set towel down.
    * finish that area (most likely needed) with a polishing cloth (the kind used to buff wax off) and a spray wax like Meg's Quick Wax or similar, sprayed a bit onto the cloth or a little onto the paint when you can (don't overspray).
    * the above will make your drying go much quicker. You will not have water spots and the car will actually be dry with a bit of spray wax reapplied to finish. Try it, it works.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I've had my mitt for maybe 9 months and it's doing great. I don't see it wearing out anytime soon.
    As for claying, try it on an older car in the household if available. When you see that it seems pretty mild, and the smudge it lifts off the paint, I think you'll be pretty interested. But, it can be time consuming, so I only do it before waxing which is months apart.
  5. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Ok. Sounds good. I'm still leaning towards the waffle weave drying cloth (much bigger) over the absorber.
    Can I substitute a microfiber cloth for the polishing cloth you mention? Or where can I get said polishing cloths for a reasonable price.
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Thank you SW.
    Basically, I don't touch the car until it's time to wash it thoroughly. I could care less if it gets some dust on it, that's life. I don't wash it every week, it may be a couple or few, but when I can, it's gets the 2 hour treatment.
    If it's quite dirty, it's going to take some time to wash it and not marr the finish.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I've not seen marring from using genuine sheepskin.
    Another thing - sheepskin releases dirt very easily when rinsing the mitt.
    Mac, I really don't think Griot's would be selling that mitt if it was bad for a car. They stake their reputation on supplies for pampering cars. That's what they're all about.
  8. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Yes that's fine. (It's what I do anyway.) Most polishing cloths are microfiber. Make sure all your cloths are de-tagged. I'd also avoid using rubbing with the edges too much, just to be extra extra safe - the sewn edges/threads can have a coarser feel that actually leaves tiny scratches or swirls.
    Anyways, microfiber is the safest thing for your car as far as I know.
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Thinking ... Autozone used to have cloths marked for glass, drying and polishing. I would think Kragen has cloths marked specifically for polishing or buffing wax off.
    I don't like using regular microfiber cloths on the paint. I use them for wiping interior, door jams.
    fyi, use glass cloths on any 'glass-like' plastic surfaces. (they had them in the 2nd gen around radio console, regular microfiber will scratch such a surface).
  10. macmaster05
    4,050
    730
    I never said sheepskin was bad. Not at all. I just personally don't use it, - and therefore I can't vouch for it.
    You're right that sheepskin is better at releasing dirt. But one good thing about microfiber is that it holds more soap and water, you can really squeeze a lot out of it.
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    If a bird or two nails your car and don't have time to wash .....
    Get out a Quik Detailer, spritz the area and get the junk up soon.
    That's all you have to do for that.
  12. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    So, are these the polishing cloths you are talking about for doing the final drying & spray wax (after using the drying cloth):
    100% Cotton Buffing Cloths, Set of 10 - Griot's Garage
  13. macmaster05
    4,050
    730
    BTW, I believe that true polishing applicators can also come in round pads, which are most of the time are microfiber. Like this;
    http://www.amazon.com/gp/product/B0009IQZQG/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B003QHWPQQ&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=13M53GCY9GDQ83XCP2NZ
    I used to do that too, until I realized how many cars their equipment has touched, how many wrong ways there are to wash a car, and how easy it is to mar a finish. I much prefer to do it myself now. I wouldn't even do it if the car wash was free.
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Streaming the water is good for getting beads off. I do a little blow dry, not much though.
    Maybe I don't have the best drying towels (they were $10 each) at Autozone. Perhaps a Griot's towel would be better.
    I dry in the garage where I can see well. Towels always get wet, even the best ones. Often the don't finish the car how I like it. I set the towel on a chair, grab the polishing cloth with spray wax and finish up the area quickly. Helps when you have something to set a towel on nearby.
  15. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I hit the spots off with some soapy water & microfiber cloths. Best I can do at the moment.
    It's the weird yellow specks and not the black & white goopy glop. It's left a mark in the clear coat, but only if you look really closely.
  16. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    You see I'm slightly confused as well. Because Griot's has both microfiber cloths for polishing, and 100% cotton ones.
    Micro Fiber Wax Removal Cloths, Set of 3 - Griot's Garage
    6-Piece Micro Fiber Cloth Set - Griot's Garage
  17. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Those would work.
    fyi, my favorite polishing cloth is the one that comes in the Meguiars Clay kit. I have two at this point.
    I believe polishing cloths have a little softer nap than regular microfiber terry cloths.
  18. macmaster05
    4,050
    730
    ^Yes yes, I see....hmmm here's how I think about it. And I may get some flack for saying this;
    100% cotton = safe. Microfiber = safer.
    As Cycledrum pointed out though, Griott's, Meguiar's, etc sell high quality products, so if it didn't work well, they wouldn't continue to sell it. However, there's just something irrationally uncomfortable to me about cotton - you wouldn't polish your car with a Hane's t-shirt now would you?
    By the way Meguiar's has an AWESOME customer support forum with video tutorials on how to wash, wax, polish, basically anything. I suggest you check it out.
    Car Care Forums: Meguiar's Online
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    If you every have a surface scratch in the finish or small area of marring, Nu Finish Scratch Doctor , orange tube, works very well. There's a kit called Quiks or SLT, that's said to be the best, but costs more.
    fyi, in case you have a scratch.
  20. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    What do you think of the Mother's clay kit. The only reason I ask is it's about $17 at Kragens.
