Best catalytic converter anti-theft device, Gen 2?
Discussion in 'Gen 2 Prius Main Forum' started by bnprius, Nov 6, 2021.
  1. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    We had the top of the line Miller Cat Shield installed on our Prius and wound up taking it off. Our mechanic spent over a week trying everything he could think of to get it to stop rattling before he even allowed us to take it home. We finally couldn't take the rattling anymore so now the shield just sits propped up against the wall of the garage, waiting for us to either figure out something to do with it or donate it to one of the local thrift shops and make it someone else's headache. Nice idea but a total waste of money.
  2. bnprius
    bnprius Our Prius at 200K
    27
    Ypsilanti Michigan, USA
    Vanessa,
    Thanks for your comment on my post from November 2021. Back then I decided to go with MillerCAT. It did seem to solve the theft problem, since my new OEM cat has not been stolen again. This, despite frequent ongoing reports of cat thefts in our area (Ann Arbor-Ypsilanti MI).
    However, the original MillerCAT rattled against the engine, despite the Toyota dealer having installed it carefully following MillerCAT's instructions. The dealer was able to bend out the shield's louvers, which seemed to cure the problem, until it started up again. That time, the dealer made a video showing that it "popped" up & down. When I sent this video to MillerCAT, they offered to replace the shield with a completely redesigned one, for free. Of course, the costs for taking off the old one and installing the new were covered by me.
    The redesigned MillerCAT is a huge improvment over their original design. It has never rattled, not once.
    Bill in Michigan
  3. bnprius
    27
    Srellim234, here's a quote from my reply to Vanessa:
    After our cat was stolen from our Prius in 2021, I had our Toyota dealer install the best MillerCAT stainless steel shield for the Gen 2 Prius.
    I recommend that you call MillerCAT and ask them to send you the completely redesigned shield--for FREE. You can tell them that they did this for me, Bill Nolting in Ypsilanti MI.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,433
    2,394
    Taylors, SC
    Any kid in high school shop learns that a flat sheet of metal will flop around like a flag in the win.
    Adding longitudinal folds or crowning the sheet like they do with body panels on cars gives the sheet metal structure and rigidity.
    Simply bending three longitudinal radial flows with the lowest part under the exhaust pipe of cat totally eliminates contact from vibration as the car is driven.
    I did this with the flat cat shield that I put on my Prius v. The same can easily be done with ant Gen 2 cat shield.
  5. MufflerTech
    MufflerTech New Member
    Sacramento
    Hey all! I may have an additional solution to your cat being stolen through our business Muffler Tech in Sacramento. We now fabricate and sell Locking Exhaust Bolts ( attaches up near Exhaust Manifold and down by rear muffler) Over the years and evolution of helping customer protect their own parts this has been a game changer. You can check out this helpful video to see how they work, what they look like and where they are located. Give us a call or IM me if you need a set. ( Set or 4 locking bolts with Key = $150 shipped anywhere in the 48 states)
  6. Mr. Marty
    Mr. Marty Junior Member
    Hartford, CT
    Fast forward 2.5 years, my daughter's cat was stolen again last night from a crowded area parked on the street near Hartford CT. I thought that stealing cats was a thing of the past, but evidently there is still demand for my poor little Prius's palladium/rhodium/curium pellet cache. Going to have to revive the temp fix before I get a cheap aftermarket cat to reinstall. Glad I still had access to this thread.
  7. BiomedO1
    BiomedO1 Senior Member
    3,434
    1,788
    SacTown, Ca
    You lucky your not in CA.:(:mad:
    IMHO: any cheap visible plating/armor down there should deter most CAT thieves. That along with a cheap motion alarm - they need to jack up the car to get to it. So if the visible armor doesn't deter them, maybe a car horn & flashing lights going off as soon as they start jacking up the car. I used a $10 12VDC motorcycle alarm and spliced it into my horn and parking lamp relays. The thieves should go looking for easier targets at this point; unless they don't care if they get caught - three hots and a cot.:sleep:
  8. MufflerTech
    Sacramento
    Yeah, the CA smog is pretty intense.
  9. YoJason
    YoJason New Member
    Minneapolis
    I liked my second Gen so much I got one for my daughter who is in CA now. She was in SF visiting her boyfriend and got her Cat stolen. CA sucks for the smog crap. Getting an aftermarket cat is not an option and a CARB one is worth as much as the car. She is looking on market place for a used one but debating if its worth it to get a cat shield or not. I did reccoment a motorcycle motion alarm but man what a mess.
    After that happened Im looking into a cheap way to protect my cat cheap. Any ideas ? I saw a vid that even with a cheap shield they can cut front and back and not loose much time.
    #69 YoJason, Jan 25, 2025
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,034
    1,965
    NJ-USA
    Sell the Prius and buy a "less desirable" car.
    California = $$$ cat, which = more incentive to steal. Cheap ($) shield = quick & easy to defeat (very little deterrence). Expensive ($$$) shield, only somewhat more difficult to defeat (some increase in deterrence, but likely not much).
  11. Has Raf
    Has Raf Member
    180
    43
    Stoke-on-Trent, England
    A garage.
  12. Mendel Leisk
    41,236
    Helps a lot, still: sooner or later you're going to park outside somewhere, and that's when bad things can happen.
    I wrapped the rear cut point on ours with heavy chain, secured with nuts/bolts on every wrap or two, with the outermost one having permanent thread lock. Also engraved the VIN, nice and big. "Might" make them move on.
  13. Has Raf
    Has Raf Member
    180
    43
    I had my local Toyota mark the cat so it’s traceable if stolen. And they put stickers on the car to show that the cars marked. My Prius is also lifted, so cat theft is more of a risk. Lucky, no incidents yet with my Prius.
  14. The Lizard King
    89
    56
    You lifted a Prius?
  15. Has Raf
    Has Raf Member
    180
    43
    Yes, 1.6” all round. Much better in terms of potholes, kerbs, driveways etc.
  16. Shootinforamil
    Shootinforamil New Member
    Nj
    That’s sick what spring setup did you use?
  17. Has Raf
    Has Raf Member
    180
    43
  18. macman7500
    macman7500 New Member
    Los angeles
    The problem is these cheap aftermarket cats that are under $100 smell bad from the exhaust because they barely work.
  19. BiomedO1
    3,434
    1,788
    SacTown, Ca
    CAT exhaust shouldn't smell; if they do smell like sulfur - then ingredients are entering the reaction - burning out.
    Just my 2-cents....
  20. macman7500
    Los angeles
    It didn't smell bad from the OEM cat
