Best Chassis Tuning for 2014 Plug-In?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Russ McBride, Nov 15, 2016.
  1. Russ McBride
    Russ McBride Junior Member
    Mariposa, CA
    2014 Prius Plug-in
    What are people's thoughts on the best chassis "tuning" parts these days? It looks like most like the Tenabe but there are also Cusco parts. I though I'd do a strut tower and an Under Brace from Tenabe to improve the handling (although I realize that there is some debate about how much of an improvement these will actually provide). I don't understand where the 3rd piece from Tenabe goes.
    Thanks
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    The TRD rear sway bar is supposed to have the best bang for buck.
  3. Russ McBride
    Mariposa, CA
    2014 Prius Plug-in
    Any idea if the TRD be better than the Tenabe Sustec Under Brace?
  4. RightOnTime
    RightOnTime Senior Member
    745
    1,614
    183
    Kidnapped in OC, CA
    Tanabe has discontinued all sales for braces and Sway Bars in the US market - so get them while you can :cool:
  5. Russ McBride
    Mariposa, CA
    2014 Prius Plug-in
    The Tenabe Sustec Underbrace looks "burlier" to my unknowledgable eye so I think I'll go with that and their Tower Strut... unless someone can give me reasons otherwise.
    Thanks for the responses.
  6. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Looking forward to updates and comparisons after install.
  7. RightOnTime
    745
    1,614
    183
    Kidnapped in OC, CA
    Stay away from the Tanabe Tower Strut bar - you can not access your fuse panel unless you take off the bar itself. Cusco is the way to go!
    iPhone ?
  8. Russ McBride
    Mariposa, CA
    2014 Prius Plug-in
    Hmm... re. the tower bar, I already ordered the Tenabe. I guess I don't mind cutting the fuse box to use the Tenabe. Totally confused about "under" bar options. They don't make a Tenable for the plugin, nor a TRD. And having a hard time finding a Cusco....
    #8 Russ McBride, Nov 20, 2016
  9. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Cusco front power brace front sway, rear sway
  10. Russ McBride
    Mariposa, CA
    2014 Prius Plug-in
    Allllright, @RightOnTime and @Toppcat, you convinced me. I'll return the the Tenabe and get the Cusco.... No one at Cusco seems to know which parts fit the plugin. Aargh.
  11. RightOnTime
    745
    1,614
    183
    Kidnapped in OC, CA
    It's all a learning experience! Some of us have gone your path and realized a better path for others to follow. DM for more info concerning Cusco if need be
    iPhone ?
  12. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
    Call 866-448-4843 ask for Sean and make sure tell him from Priuschat.
  13. Toppcat
    Toppcat Member
    223
    69
    Northern California
    My suggestion is to start with low profile wheels and tires , reducing possible leaning angle results in less chassis twist . next reducing the center of gravity lowering spring/ coil overs? then sway bar and then bracing depend on what your trying to achive? I started w cusco frt sway and brace! like night and day over oem since cusco frt sway is 127% stiffer than stock! w a cusco frt 6 point power brace adds support for the sway and frt portion of the body! I didn't see and need for tower bracing in order tower bracing to be effective it must to 4-6 point solid not pivot type !
  14. GADGETBUNNY
    GADGETBUNNY Junior Member
    San Francisco
    I got around to installing a Cusco strut tower bar, rear TRD sway bar, and two miss chassis braces on my pip and the car feels tight, steering is much sharper, and body lean/roll gas reduced to minimal. Did NOT change tire/wheel size, or shock/strut/springs. Stock, except for the add-ons and they've made a world of a difference without sacrificing ride comfort at all. I fear the potholes with stiffer suspension so for now this makes the pip feel solid and higher quality than completely stock.
    QuantumFireball and Yea Right like this.
  15. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    Thanks for the update
