Best engine oil after 70k?
Discussion in 'Gen 3 Prius Main Forum' started by ridz, Jul 27, 2017.
  1. Mendel Leisk
    42,264
    2nd owner's manual in North America says 5W30.
  2. nicoj36
    nicoj36 Active Member
    518
    162
    Mobil 1 advanced fuel economy
  3. kamrul
    kamrul Junior Member
    99
    17
    Bangladesh
    Which one do you use the Gallon Jug (3.78 Liter) or multiple Quart Bottle (946 mL each) ?
    Because the owner's manual says to refill 4.4 qt. (4.2 L) with filter or 4.1 qt. (3.9 L) without filter.
  4. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    If the engine does not consume any oil, I think any 0w-20 with Dexos1 gen3 or VW 508/509 will give the best protection and cleaning. Valvoline also has restore and protect series. It really cleans the piston rings well over time if there is some deposit on the oil control rings.
    If the oil consumption has started and not too bad (cylinder wall still good), Valvoline restore and protect will unlodge sludge snd carbon on the rings. It was proven by used oil analysis from the higher Mn reading. Mn is common in varnish on the engine that came from octane booster additives in fuel.
    Jim Swart likes this.
  5. nicoj36
    518
    162
    Mobil 1 hybrid
  6. kamrul
    99
    17
    Bangladesh
    My 2013 has nearly 85K miles on it. I would love to try Valvoline Restore & Protect but it is not sold in my country.
  7. johnHRP
    646
    189
    KA, DE
    Excel
    @kamrul if you live in Europe, just grab 0w-20 longlife IV 508/509 that has higher standard than API SP or SN qualifications.
    VW sometimes claim to have longlife 20k miles interval but I don't recommend to do 10k miles interval even with VW Oil.
    I found Total Ineo and Fusch is affordable and has higher PAO contents with -55C poir point. Cheaper oil has highet pour point like Mannol or Eurolube -45C.
  8. ASRDogman
    ASRDogman Senior Member
    8,043
    4,076
    Don't waste your money. It's like snake oil.
    I started using it on 8 March 2024, at 330,277 miles.
    And I used seafoam for 500 miles before changing.
    I changed every 5000 miles, give or take a few hundred
    depening on when I was able to get it changed.
    I turned 363,000 miles today.
    I am not burning any less oil.
    Not that the engine was dirty, but if that stuff worked. it would have cleaned out the oil rings
    and oil consumpsion "should" have gone down.
  9. johnHRP
    646
    189
    KA, DE
    Excel
    @ASRDogman, It is most likely the cylinder walls are already worn out and the cross hatch pattern are missing on some spots and cannot hold oil anymore. I am curious if you ever inspect them with borescope.
    The 2.5L engines are also known to have cylinder walls damaged from 10k mile oil change interval.
    Mine does not consume engine oil although my timing cover leaks and the oil does not even drop 1mm between oil change.
  10. johnHRP
    646
    189
    KA, DE
    Excel
    Between all kind of Mobil 1 0w-20, the Truck and SUV mobil 1 has the most superior formulations. Longest life and for heavy duty antiwear with better Base oil (PAO + Alkylated Naphthalene)
  11. misterduck
    misterduck Junior Member
    Earth
    Regarding the original question, I think frequent, regular oil changes are more important than the specific oil. In this car, I think any full synthetic 0W20 is fine. I buy mine at Costco.
    I think Toyota's oil schedule is unnecessarily aggressive. Oil is cheap and easy to replace (for me, something like ~$26 per change); I prefer a 5k schedule to be conservative.
    johnHRP likes this.
  12. johnHRP
    646
    189
    KA, DE
    Excel
    I agree, but if I can choose for the same price. Mobil1 Truck and SUV is a really good one. Better than more expensive, the extended performance Mobil1.
  13. timardis
    timardis Junior Member
    Houston
    I
    Always bought Kirland 5W30 when it went on sale, but it doesn't get too cold here
  14. johnHRP
    646
    189
    KA, DE
    Excel
    It is nothing so much about cold or hot weather, but cold start is the main cause of engine wear. There is a reason why many cars manufacturers use 0w-30, 0w-20, or 0w-8 now. The viscosity of 10w-60 at 200F is thinner than 0w-8 at 40F.
    The engines like to get to the working temperature viscosity, which is at around 200F. So, using 0w-20 is better thn 5w-30, as long as the car is design for 20 weight. You can use 0w-30 instead if you like a bit quieter engine. Thicker oil always make the engine quieter but not so good in cold starts (max wear).
