Best front brakes and rotors?
Discussion in 'Gen 3 Prius Main Forum' started by Steelerfan2018, Feb 13, 2023.
Tags:
  1. Steelerfan2018
    103
    42
    Pittsburgh
    Hi all,
    I will be doing my front brakes shortly, and was thinking of doing them myself (with the help of a buddy - money is tight).
    So - Q - what is a good brand for brakes and rotors? Also, do I really need to change both - or can I just do the brake pads? (with the rotors looking OK).
    Thanks,
    Rob
  2. JC91006
    16,936
    8,647
    if your rotors are not bad, just change the pads. The pads should be OEM, since you only change them once or twice in the life of that car. Go for quality
  3. Mendel Leisk
    42,310
    Yeah Toyota pads and shims, and the rotors sound fine. You can check rotors against spec, with dial gauge (with magnetic base) and micrometer. Acquiring both instruments would be about $50~75 USD.
    My signature has a link with brake job tips and repair manual excerpt, has torque values and rotor specs.
