Best fuel mileage 18's
Discussion in 'Gen 4 Prius Fuel Economy' started by djarmy2004, Feb 4, 2018.
  1. djarmy2004
    djarmy2004 Junior Member
    17
    Dale, Indiana
    So I had factory 15s and was getting 48mpg average on my prius 4, I drive 78mph most the time to and from work on the highway. well I upgraded to 18s and now get 34. is there a better fuel efficient 18" people have tried or had good luck with. 20180129_105744.jpg
    SM-G955U ?
  2. Rmay635703
    Rmay635703 Senior Member
    2,688
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    krmcg likes this.
  3. djarmy2004
    17
    Dale, Indiana
    and what makes that 19 so good?
    SM-G955U ?
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    How many tanks have you used with your 18"? I'd do a minimum of 2 full tanks before panicking.
    RCO likes this.
  5. fuzzy1
    10,690
    When did you change tires? Do remember that MPG falls in winter even without changing tires.
    What actual tire size did you get? Any change in tire diameter will change speedometer and odometer readings, messing up your MPG calculations.
    RCO and alanclarkeau like this.
  6. alanclarkeau
    7,045
    7,593
    And - you might need to increase the pressure - PRIUS runs fairly high pressures, and if you're running the "recommendation" of the tyre place, they're probably a guess. Add a few more.
    RCO and padroo like this.
  7. djarmy2004
    17
    Dale, Indiana
    I'm on my second tank of gas, I will have to look at the tire size, my mph changed by 1. as far as mpg this winter I had been getting 45 and summer I get around 48 to 50. but now im.at 35mpg
    SM-G955U ?
  8. padroo
    padroo Senior Member
    2,763
    2,253
    I doubt it that the choice of low rolling resistance tires is that great especially in the size you need.
    I would contact tirerack.com and ask them, they are real good at getting back to you by email.
  9. djarmy2004
    17
    Dale, Indiana
    thanks padroo
    SM-G955U ?
  10. Mendel Leisk
    42,296
    @djarmy2004 just curious: what are your current 18" tires?
  11. padroo
    2,763
    2,253
    I have a black 2016 and bought wheels that look like yours except they are 15 inch American Racing.
    I haven't installed them yet.
  12. djarmy2004
    17
    Dale, Indiana
    Falken Ziex 225/40/18 20180204_235434.jpg 20180204_235530.jpg 20180204_235440.jpg
    SM-G955U ?
  13. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    I'm on 18's and currently getting anywhere from 55-57 mpg per tank fill up. Reseting trip A at every tank to verify. Using Nankang - Noble Sport.
    I check my tire pressure often to make sure it good. Once it drops too much I instantly lose 5-7 mpg easy.
  14. Mendel Leisk
    42,296
    What pressure?
  15. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    Tire pressure usually around 40/42 gets best milleage for me.
    When it dips down close to 35 ish is when I see the mileage start to drop.
  16. padroo
    2,763
    2,253
    From what I can find the diameter of your tires are slightly larger than the stock tires and they are performance tires and not LRR.
    It's a double whammy for gas mileage and winter. It can't get much better.
    RCO and pilotgrrl like this.
  17. alanclarkeau
    7,045
    7,593
    Is that by calculation - or a readout from the dashboard?
  18. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    It's by trip calculations. After fueling I reset the trip meter.
    RCO likes this.
  19. djarmy2004
    17
    Dale, Indiana
    what size are your 18s? I will have to raise my tire pressure to 42 front and 40 rear and try that
    SM-G955U ?
  20. alanclarkeau
    7,045
    7,593
    Because it's calculated by the computer, from a lot of inputs across many many trips, it is only fairly approximate - most people's real calculations (litres/km or whatever) are between 6 and 12% optimistic - every brand of car I've had has been optimistic, funny that.
    With the optimistic error of the trip-calculator, that probably means that 55-57 mpg would be lower.
    RCO likes this.
