Best full synthetic 5w40 for 2012 for the money?
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Feb 4, 2021.
  1. nudriver
    nudriver Member
    218
    26
    los angeles
    What's your vote boys?
  2. ozmatt
    ozmatt Active Member
    571
    234
    australia
    Anything full synth it doesn't really matter mate just steer clear of oil promoting zinc because its known to clogs cats
  3. ASRDogman
    ASRDogman Senior Member
    5,908
    3,167
    Castrol, Mobil One, Havoline, pretty much any major brand.
    Probably should stay away from off the wall brands.
  4. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Amsoil signature series.
  5. Leadfoot J. McCoalroller
    6,842
    6,484
    Pennsylvania
    2018 Prius c
    It's going to be hard to find a bad choice- lots of strong competition in that grade. I would avoid Shell Rotella and other ZDDP-enriched oils.
    That 1.8L engine likes to burn oil and when you burn ZDDP-enriched oil in a gasoline engine you wind up ruining the catalyst faster than normal. In a Prius under CARB rules in California that's an expensive problem, not something you want to mess with.
  6. bettergolf
    bettergolf Active Member
    411
    332
    Sanford NC
    Key words in the question here....."for the money". Nobody has mentioned cost at all...I know, I know...don't sacrifice a few bucks on the life of your car.....but that wasn't the question.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    Why that choice of weight ?
    If you need 40 because of high oil usage, there is no need for a 5 lower number.
    A 15W40 would be easier to find and might be less expensive too.
    A "high mileage" variety might be good.
  8. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Any oil that has zinc excess over 700-800 ppm is not certified by api nor gets the seal on the label oil bottle.
    For OP Just go with Toyota oem 0w-20 since drive climate and mileage is not to be shared.
  9. Mendel Leisk
    38,253
    I’m getting that in bulk, through dealership, very good price, around $3 CDN per litre. Bring a sturdy 10 liter gas can, usually get 9 litres (doing two cars).
    Grit likes this.
  10. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    opposite, I buy individual quarts because it’s cheaper by the unit. Redline by the gallon is more expensive compared to 6 or 12 quart package. And the zinc is within 1,200 ppm :LOL:
  11. Mendel Leisk
    38,253
    Just checked receipts: they’re charging me $2.80 CDN per litre (about $1.98 USD per US quart). Probably their cost? I appreciate it’s a sweetheart deal.
    Jim Swart likes this.
  12. magnumrtawd
    magnumrtawd Member
    305
    71
    Toledo,Ohio
    My local shop changes my 0-20 full synthetic every 12mo.or 10,000 mi. rotates and balance tires for 39.95 . Don't know or care what brand of oil they use!
  13. orenji
    orenji Senior Member
    5,884
    3,486
    Mobil 1 oil weight 0W-40 has been great, No oil usage and at 120k miles.
    Aaron Vitolins likes this.
  14. t_newt
    t_newt Active Member
    216
    240
    Since this question was about cost:
    The Project Farm Youtube channel did a test of synthetic engine oils. He didn't test 5W-40 but the results may apply to that viscosity too.
    AmazonBasics did very well in his tests.
    Here's another test he did that included AmazonBasics.
    For fun, he also has videos where he tries WD40, vegetable oil, and even banana oil in an engine to see how it does.
  15. nudriver
    nudriver Member
    218
    26
    los angeles
    What do you mean "likes to burn oil"? Is my Prius typical in the fact that it's burning oil?
  16. nudriver
    nudriver Member
    218
    26
    los angeles
    I have a follow up question. I have messed up piston rings and my car burns oil. I don't know what the oil type is supposed to be, but my mechanic is telling me to buy 5W40. I believe it's because he thinks a thicker oil is necessary to preserve engine life. Is this safe?
  17. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    depends on your driving climate, seasonal temp changes and how you mash the gas pedal before engine gets to 150F. If your up north and it’s snows, 5w-40 would choke your engine on non highway driving.
  18. ASRDogman
    5,908
    3,167
    Thicker oil will help a little, but, it will make the VVT work harder, or not correctly.
    You could try the BG products that are supposed to remove the gunk from the rings and other
    engine parts. Some say they have noticed a difference.
  19. nudriver
    nudriver Member
    218
    26
    los angeles
    What's VVT?
  20. nudriver
    nudriver Member
    218
    26
    los angeles
    I drive in a warm climate mostly.
