Best Gasket sealer
Discussion in 'Gen 2 Prius Technical Discussion' started by muzzleloader48, Dec 3, 2022.
  1. muzzleloader48
    muzzleloader48 New Member
    Colorado
    2007 Toyota Prius Base - 1.5L gas engine:
    I am rebuilding the engine. What is the best gasket sealer to use?
  2. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    It has been a few years but the toyota form in place goop was highly rated. Even by my subaru tech.
  3. Mendel Leisk
    42,345
    @danlatu shows a can of Permatex Copper Spray-A-Gasket here. I thought there was some discussion about it too, but not finding it. Just Googling, opinions on using something like this are "mixed".
  4. Aegean
    Aegean Active Member
    464
    209
    Alexandria VA
    I would recommend Hondabond 4. It is used successfully for motorcycle motors that have higher rpm’s and loads.
  5. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
  6. Mendel Leisk
    42,345
    For what, specifically?
  7. MCCOHENS
    252
    101
    Chalfont, PA
    Different situations need different stuff. The toyota FIPG is at the top of the list, but copper spray for head gaskets, water pump sealer for corners of water sealing stuff, etc.
