Best headlight bulb
Discussion in 'Gen 3 Prius Accessories and Modifications' started by nicoj36, Nov 26, 2016.
  1. nicoj36
    nicoj36 Active Member
    518
    162
    Hi everyone,
    I was wondering if you guys could recommend the best and brightest headlight bulb for our 3rd gen prius? It doesnt matter whether its an LED, HID, etc.
    I just want the best headlight bulbs for my prius!
  2. PriusNP
    PriusNP Junior Member
    85
    17
    Led 6k
    Hid are great but led is brighter and most likely to last longer.
    I have used both
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    35w AC HID. 4300K is brightest, and is oem color on most vehicles equipped with HID.
  4. 12voltman
    12voltman Member
    124
    93
    H9 conversion is the best bang for the buck .
    Just remove your standard H11, bulb, make a simple modification to an H9 bulb, and put it in. MUCH better and brighter bulb. Better light spread as well . Did mine about 2 years ago, when I was frustrated with the stock H11's. Couldn't be any happier with the swap, and still going strong. A side benefit to the H9 conversion is the high beams are exceptionally bright now. Plus its a pretty cheap upgrade. H9's are dirt cheap.
    H11 to H9 Headlight Bulb Conversion | PriusChat
    #4 12voltman, Nov 27, 2016
    Princer likes this.
  5. haigenIII408
    haigenIII408 New Member
    US
    What brand do you use for your led kit ?
    Dylan Doxey likes this.
  6. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    What brand?
  7. cobraz
    cobraz Prius Pirate
    81
    26
    2018 Prius
    After reading many comments and watching youtube vids..I went with xenonsupply.. and got the 6000k white HID upgrades. Bright for driving noticeable by others. Interesting fact the higher k factor does not make them brighter on the road..and the burn hotter..just others see you miles away..
    On sale today $41.00 off..bonus.
    SAMSUNG-SM-G925A ?
  8. Mendel Leisk
    42,351
    @nicoj36, all the moder's are going to chime in, with their dream headlights. Some might work well, some might be problematic, burn out fast, or even cause oncoming drivers to blindly veer off the road, lol.
    Worth considering though: the "best" bulb might be the one that's in there. Worked, lasted 6 years?
    mmmodem and Dylan Doxey like this.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    You have basically 3 choices, higher wattage H9 bulbs, LED, or HID.
    Let's just throw LED out the door for now as the technology is not plug and play ready. The ones for sale now will be dimmer than OEM. You'd have to do a whole headlight retrofit costing thousands to do it correctly.
    I tried higher wattage in my previous car and one bulb burned out after a few months, the second went not long after. Didn't even last a year.
    HID is your brightest option. I installed that on my Prius. The ballast shorted a few months later. Looks like moisture got into it. I'm done with HID. It's so bright that it causes random hotspots in your field of view. While very bright, it was very annoying, I was ready to remove them even before the ballast burnt out. I tried readjusting to no avail.
    That's my adventure with alternative lighting. I'm back on plain old yellow OEM incandescent. 4 years old now. I would love to move to LED but like I said, all examples I've seen so far are much dimmer than OEM.
    solrunner and Princer like this.
  10. cobraz
    cobraz Prius Pirate
    81
    26
    2018 Prius
    I used HID in my headlight bucket on my Honda converting the bike LED everywhere else..the HID was amazing and 3 times the distance in seeing down the road along with sides as well...but you get what you pay for..cheap parts from no names agree are not worth it.
    SAMSUNG-SM-G925A ?
  11. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I just installed Hella H9 bulbs. The mod was pretty easy. The only hard part was when I dropped one of the old bulbs and I had to jack up my car and remove part of the apron to get the old bulb. Cause I'm a dumbhead. Don't drop the lightbulb: Check.
  12. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    Over the weekend I tried a set of LED bulbs and a set of HID bulbs.
    The LED bulbs were at least twice as bright as the stock halogen bulbs however they don't throw the light as far.
    The HID bulbs were probably 3 times brighter than the halogen bulbs and the distance is much better than halogen bulbs and LED bulbs.
    So in the end I returned the LEDs and went with the HID.
    I bought my kit from Amazon, the brand is innovited. Very high quality for a cheap kit. I highly recommend them.
    I bought the 55w 5000k kit. Pure white light, no flickering, fast warm up, and an excellent cutoff with my stock headlights.
    I have a lot of experience with HID, I retrofitted my 2 rav4's headlights, as well as bought jdm headlights, I've used original denso ballasts with Toshiba bulbs, so when I say this kit is quality I really mean it.
  13. xliderider
    8,140
    3,280
    Honolulu, HI
  14. mariposer
    mariposer Junior Member
    33
    17
    Hot Springs Village, AR
    Three Touring
    I need to headlights that will cut through the fog. That's a big issue for me and my 2015.
    Any suggestions?
  15. xliderider
    8,140
    3,280
    Honolulu, HI
    You need a good set of foglights with sharp cutoffs. Also, yellow 2500K color temp bulbs help you see much better in foggy and rainy conditions.
    Princer and Starbrand like this.
  16. djstretch
    djstretch Junior Member
    US
    what bulbs are you running, they are very white
  17. xliderider
    8,140
    3,280
    Honolulu, HI
  18. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    I have seen several kits on amazon like this, could you be more specific? Also, is this the one you still prefer?
  19. AR4CE1
    AR4CE1 Junior Member
    Richmond,VA
    Following.I need for my 2011 Prius,some white light 6000K plus LED's
  20. nicoj36
    518
    162
    I tried LEDs and was disappointed. I found HID the best.
    PriusHead05 likes this.
