Best HID kit brands
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Steve terry, Oct 28, 2013.
  1. Steve terry
    Steve terry Member
    217
    Oklahoma
    I had a hard time finding a good spot for the ground wires. I put one on the inverter so now I want to move it. Not a lot of good places to put it with legnth of eire. Any suggestions?
  2. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    Do u have any issue without using the relay for your hid kit? I have installed my kit 1 week ago and I have left it on even on day time. So far I have no issue and the brightness for 55w is really good.
    This is without installing the relay that come together with my kit.
    iPhone ?
  3. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    I just installed this kit , the video on line is for a 2011 Prius and the kit shown was not exactly what was sent. On my 2010 prius II, the 2 black modules would not slide down under the fuse box, but were so big, they had to be mounted above the fuse box cover , it works, but is a bit of a pain to get the fuse box cover off. The wires were a lot longer than in the Xenon supply install video shows, so with some messing around it could be made to work. On the passenger side again the size of the modules made it a pain to find a place for them under the the overflow reservoir , I ended up mounting one module on the top off to the fender side. Not as easy as the video shows but with w bit of tinkering it can be made to install OK. Not quite plug and play, more like find what works for your install, and cob it in.....
  4. Steve terry
    Steve terry Member
    217
    Oklahoma
    I know this may not be what you wanted but took it last night
      File size:
      27.8 KB
      553
  5. Steve terry
    Steve terry Member
    217
    Oklahoma
    I hear you on that not plug and play.
  6. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
  7. Smogmonster
    Smogmonster New Member
    Are there any concerns with a 50 W kit vs 35W? Heat, ballasts or do they work just fine? Has anyone ever got false warnings on their dashboard with these kits or do the ballasts eliminate the error codes?
    Thanks.
  8. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Get good quality AC digital ballasts vs DC ballasts for longer bulb life.
    Also, most manufacturers recommend using an HID relay that draws power from the battery (fuse block in the Prius) instead of the car's headlight circuit for more reliable operation.
    SCH-I535
  9. Smogmonster
    Thanks for the information...
  10. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Mine has worked fine for two years and over 80,000 Kms. No need for relay if you have a reasonable quality system. No heat problems.
  11. Joele3
    Joele3 Active Member
    136
    205
    Bay Area
    +1 on the Retrofit source hid kit. I've used their projector retrofit kit on my gen 2 still going strong. Now I have the HID kit for my gen 3. I did have an issue with it. I was installing but one of the lights would not work. Triple checked all my wiring and grounds, ended up being a bad relay. They sent me a new one right away did not charge or was I required to send the bad one back to them. I went with 50w xb35 morimoto bulbs 5000k
  12. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Sweet bulbs right?
    Very nice output with the 50 watt ballasts.
    Very close to the look of OEM Prius LEDs...
  13. Joele3
    136
    205
    Bay Area
    Very much so ! I have the 5000k on my old prius. I went with the xb35 bulbs for the ground shadow issue.
    It was the first thing I did when I got my gen 3 was slap in some HIDs.
  14. bathala
    bathala Member
    128
    30
    Area 52
    Where can I purchase those type of female terminal? Looks like the spade terminal is housed in a plastic case with snap-on type of lock. Thanks.
  15. xliderider
    8,140
    3,277
    Honolulu, HI
    They're available at auto supply, hardware, and at Wal-Mart, etc. Look in the automotive electrical section, or in wiring, car stereo sections, etc.
    SCH-I535
  16. bathala
    bathala Member
    128
    30
    Area 52
    Any recommendation where I should run the relay harness and also be able to secure it properly? Thanks.
  17. varun singh
    varun singh Member
    113
    Wayzata
    I just ordered 50w xb35 morimoto bulbs 4300k, how do you like so far, any words of wisdom :)
    I am bit skeptical on heat, did you you notice them running over heated ?
  18. Feri
    Feri Active Member
    761
    144
    Hi Varun, Not sure if your question is to me but my generic Phillips licensed ballasts have given no trouble. They get hot but are touchable!
  19. varun singh
    varun singh Member
    113
    Wayzata
    Thanks, 50W morimoto ballast with XB35 should be good then, I live Minnesota and got pampered with TSX :)
    By any chance were you using 50w ballast ?
  20. Feri
    Feri Active Member
    761
    144
    Yes!
